I am trying to get an RTL8720 to communicate with a Wiz5500 Ethernet module using the SPI bus.
Main code (given just below) as well as two read (read.h) and write (write.h) functions in separate TABS.
#include <SPI.h>
#include "definitions.h"
#include "read.h"
#include "write.h"
#define SPI_HAS_EXTENDED_CS_PIN_HANDLING 1
#define SPISettings my_spi(40000000, MSBFIRST, 0);// SPI setup, 40 MHz clock speed
#define SPI_MODE 'M'
uint16_t address = 0x0000;
byte control = 0b00000100;
byte reg_Data = 0;
Serial.println("VERSIONR Register Test!");
SPI.begin();
delay(1);
Serial.print("VERSIONR Address -- ");
Serial.println (VERSIONR, HEX);
Serial.print ("CONTROL -- ");
Serial.println (control);
Serial.print ("VERSIONR -- ");
Serial.println (reg_Data);
Serial.println (); Serial.println ();
The code in the read.h TAB is given below. write.h has almost same code.
byte read_reg(uint16_t address, byte control,byte reg_Data){
if ((control & 0b00000100) != 0b00000000){
byte Acontrol = control | 0b00000000;
SPI.beginTransaction(PA15,my_spi);
SPI.transfer16(address);
SPI.transfer(Acontrol);
SPI.transfer(reg_Data, SPI_LAST);
delay(1);
SPI.endTransaction();
digitalWrite(PA15, LOW);
return(reg_Data);
I am getting the error message copied below i.e. "my_spi not declared in this scope"
C:\Users\M1\AppData\Local\Arduino15\packages\realtek\hardware\AmebaD\3.1.7\libraries\SPI exit status 1'my_spi' was not declared in this scope
What am I doing wrong. Please help
TIA
azhaque
