Define with or statement
Hello,
I'm new to C++ and am trying to figure out some of the language.. I'm attempting to make it so if I have 3 different buttons on an IR remote that they correspond to a single case statement. I know I can have 3 separate ones set up like: Case 1: Case 2: Case 3: for an or statement, but is there a way when I define the case name corresponding to the hex number from the remote they can be in an or statement? I was trying it like:
#define case1 0xFF42BD || 0xFF4AB5 || 0xFF52AD
That didn't work, is it even possible to have an or like this?
Thank you!
It is possible to define a text string that contains an OR operand like that. It is NOT possible to define a case statement that uses an OR operator.
If you want a code block to be activated when the switch variable is 0xFF42BD or 0xFF4AB5 or 0xFF52AD then you can do it like this
case 0xFF42BD:
case 0xFF4AB5:
case 0xFF52AD:
//code for the cases goes here
All those values are non-zero, so what you've done is effectively
true
