Define's im laufenden Programm verändern/ Library vorgaben umgehen
Hallo,
ich habe habe ein kleines Problem mit einer Variablen. Ich verwende einen Sensor der einen analogen Wert an das Arduino sendet. Dieser Port muss allerdings laut Bib vorab definiert werden.
 * HIH4030_HumiditySensor_Example.ino
 * E.Robert @ SparkFun Electronics
 * original creation date: November 5, 2016
 * https://github.com/sparkfun/SparkFun_HIH4030_Arduino_Library
 * Functions: Allows you to set supply voltage, define whether or not a temperature
 *            sensor is being used, define static temperature value in absense of a
 *            temperature sensor, and utilize the equations supplied by the manufacturer
 *            to acquire accurate measurements of Relative Humidity (RH%).
 *            https://learn.sparkfun.com/tutorials/hih-4030-humidity-sensor-hookup-guide
 *            Note: TMP102 Sensor is being used in this example as part of the
 *                  SparkFun HIH-4030 Humidity Sensor Hookup Guide. However, other
 *                  temperature sensors can also be used in this sketch by replacing
 *                  the necessary code inside the getTemperature() function.
 * Resources:
 * Wire.h - Arduino I2C Library
 * SparkFun_HIH4030.h - Arduino Library for SparkFun Humidity Sensor Breakout - HIH-4030
 * Development environment specifics:
 * Arduino 1.6.8
 * SparkFun RedBoard
 * SparkFun Real Time Clock Module (v14)
// Library Inclusions
#include <SparkFun_HIH4030.h>
#include <Wire.h>
// Example Variables
int tempAddress = 0x48;             // I2C: TMP102 Slave Address with ADD0 Grounded
float temp = 0;                     // Temperature Value either Static or Sensor Reading
// Are You Using a Temperature Sensor? 1 = YES / 0 = NO
int tempSensor = 0;
// Analog IO Pin Connected to OUT
#define HIH4030_OUT A0
// Supply Voltage - Typically 5 V
#define HIH4030_SUPPLY 5
// Library Variables
HIH4030 sensorSpecs(HIH4030_OUT, HIH4030_SUPPLY);
void setup(void){
  Serial.begin(9600);               // Serial Port
  Wire.begin();                     // I2C: Utilized by TMP102 Temperature Sensor
/* Serial Output of Temperature C, Sensor Voltage V, SensorRH %, and TrueRH % */
void printData(HIH4030 sensor, float temperature){
  Serial.print("Temperature = ");
  Serial.print(temperature);
  Serial.print(" C ("); Serial.print((temperature * 9/5) + 32); Serial.println(" F)");
  Serial.print("Sensor Voltage = ");
  Serial.print(sensor.vout());
  Serial.println(" V");
  Serial.print("Relative Humidity = ");
  Serial.print(sensor.getSensorRH());
  Serial.println(" %");
  Serial.print("True Relative Humidity = ");
  Serial.print(sensor.getTrueRH(temperature));
void loop(void){
  /*  IF tempSensor = 1 Utilizing a Temperature Sensor             */
  /*  IF tempSensor = 0 Utilizing a Static Value for Temperature   */
  if (tempSensor == 1) {
    temp = getTemperature();        // Get Temperature Sensor Reading
  } else if (tempSensor == 0) {
    temp = 25;                      // Static Temperature Value in C
                                    // Set by User to Desired Temperature
    while (tempSensor != 1 || tempSensor != 0){
      Serial.println("ERROR: tempSensor Value Out of Range");
  printData(sensorSpecs, temp);     // Print Sensor Readings
  Serial.println("");               // Return Space Between Readings
  delay(100);                       // Slow Down Serial Output
/* Only Called IF Temperature Sensor is Being Used */
float getTemperature(){
  /*  IF Temperature Sensor is different from the TMP102 and not   */
  /*    utilizing I2C via the Wire.h library, replace the code     */
  /*    within the getTemperature() function.                      */
  Wire.requestFrom(tempAddress,2);  // Wire.requestFrom(address, # of bytes to request)
  byte MSB = Wire.read();           // Receive byte as MSB or left-most bit
  byte LSB = Wire.read();           // Receive byte as LSB or right-most bit
  /*  TMP102 Temperature Register 12-bit, read-only, two's compliment for negative */
  /*  << is bit shift left ; >> is bit shift right ; | is bitwise OR               */
  /*  Syntax:   variable << number_of_bits                                         */
  /*            variable >> number_of_bits                                         */
  int TemperatureSum = ((MSB << 8) | LSB) >> 4;
  float celsius = TemperatureSum*0.0625;  //One LSB equals 0.0625 C
  return celsius;
https://learn.sparkfun.com/tutorials/hih-4030-humidity-sensor-hookup-guide/all
Mein Problem ist, dass ich den Port in meinem Programm erst später über eine INI-Datei einlesen will.
Kann ich den Port irgendwie erst später eingeben? Danke schon mal.
Warum instantiierst du die Dinge nicht erst, wenn du dir mit den Pins einig bist?
Ansonsten, weiß ich nicht was ein Bib ist, und die Library kenne ich auch nicht.
Der Titel "Define's verändern" wird dir keinen Millimeter weiter helfen.
Denn deine defines kommen auf dem µC nicht an, die werden schon beim kompilieren aufgelöst.
Von was für einem Port sprichst du ?
Oder meinst du einen einzelnen Pin ?
Dann schreibe einfach mal welchen Pin (so nennt man einen einzelnen Anschluss) du meinst.
Herrx:
Die Bibliothek sieht keine Methode vor, das zu tun und pin ist private.
Lösungsmöglichkeiten:
  • Du veränderst die Bibliothek.
  • Du überträgst die Funktionalität der recht einfachen Bibliothek in eigene Funktionen und verwendest die Bibliothek nicht.
Dein Titel passt nicht zu deiner Frage.
Ja man kann precompiler definies verändern.
Das ändert den Wert für deinen Kompiler.
Das ist aber alles vorbei bis du zur Laufzeit eine INI Datei auslesen konntest.
Ergo: alles umbauen so wie Combie/Agmue schreiben.
combie:
Mhh ja das dachte ich mir fast.
Ich will die Software flexibel halten und weiß noch nicht ob ich den Pin A4, A5, A6 oder oder nehmen. Wollte es erst später über eine INI-Datei einlesen.
(Hardware: Arduino Mega mit Eth-Shield und SD-Karte)
Ok. Ich glaube ich muss dann wohl ohne Library auskommen und mir selber die Funktion schreiben. Danke trotzdem.
Herrx:
Ich glaube ich muss dann wohl ohne Library auskommen ...
Mache Dir doch Herrx_HIH4030.h mit einer Methode changePin.
Ich sagte:
"Warum instantiierst du die Dinge nicht erst, wenn du dir mit den Pins einig bist?"
Wozu da eine andere Lib her soll, oder diese nicht taugen soll, KA...
Beispiel: (ungetestet)
const byte pins[] {A1,A0,A7,A6};
void printData(byte pin);
 Serial.println("Start");
 for(byte pin:pins)   printData(pin);
  HIH4030 sensor(pin, HIH4030_SUPPLY);
während ich googelte hast du ne Lösung. Egal, ich bringe es nach:
das Problem für mich als Anfänger ist da der Scope.
Wenn ich das Objekt erst im Setup nach dem Lesen einer INI initialisiere, verliere ich das Objekt am Ende von Setup.
Google bringt mich hier hin:
I found it the easiest solution, to declare my object as a pointer and init it in setup.
Das letzte Bespiel würde ich versuchen.
(nicht in Codetags, weil ich nicht weis obs geht)
HIH4030 * sensorSpecs;
   // INI-Datei auslesen und HIH4030_OUT bestimmen
   sensorSpecs = new  HIH4030(HIH4030_OUT, HIH4030_SUPPLY);
    Serial.print(sensorSpecs.getSensorRH());
(nicht lauffähig - klar)
Wenn schon Zeiger...
Serial.print(sensorSpecs->getSensorRH());
copy paste von dir und aus dem Netz ... klappt natürlich nicht immer :wink:
Erleuchte mich: warum brauch ich in Setup das new und du klopfst es einfach in der Funktion ohne hin?
:grin:
Du definiertst einen Zeiger.
Dann musst du auch mit new einen Bereich im Heap reservieren, wo der Zeiger drauf zeigt.
Und auch gegebenenfalls mit delete wieder freigeben
Ich instantiiere ein Objekt auf dem Stack
combie:
Es war als Alternative gedacht, aber wenn es einfacher geht, dann gerne einfacher :slight_smile:
Welcher Weg der richtige ist, muss jeder anhand der Anforderungen und seiner Fähigkeiten, selber mit sich aus machen.
Einen Setter hinzufügen ist sicherlich auch eine "gültige Maßnahme"
Die Bewertung "besser/schlechter?" muss ich nicht treffen.
:slight_smile:
Danke für die vielen guten Ideen. Habe auch noch was zu Zeigern gelernt.
Habe jetzt einfach aus der Beschreibung des Sensors die Formeln genommen und in eine Funktion gepackt wo ich den eingelesene Wert vom Pin übergebe und die relative Luftfeuchtigkeit zurückbekomme.
float fGETHMD(int _iaHMD)
  float _fHMDBerechnen;
  _fHMDBerechnen = (float)(_iaHMD *5)/1023;
  _fHMDBerechnen = (_fHMDBerechnen/(0.0062*5)-25.81);
  _fHMDBerechnen = _fHMDBerechnen/(1.0546 - (0.00216 *rtc.getTemp()));
  return (_fHMDBerechnen);
Ist vielleicht im Gegensatz zu euren Varianten ein bisschen Brechstangenstyle. Aber läuft.
Mir hat mal jemand geschrieben: "Ein funktionierendes Programm ist ein gutes Programm!"
Und eins, das Du verstehst, ist noch besser.
tja, wenig überaschender Weise macht die Lib fast das gleiche:
// Convert sensor reading into Relative Humidity (RH%) using equation from Datasheet
// VOUT = (VSUPPLY)(0.0062(SENSOR RH) + 0.16), typical at 25 degrees Celsius
float HIH4030::getSensorRH() {
 return ((vout() / (.0062 * supply)) - 25.81);
// Get True Relative Humidity (RH%) compensated with Static Temperature or Measured Temperature
// TRUE RH = (SENSOR RH)/(1.0546 - 0.00216T), T in degrees Celsius
float HIH4030::getTrueRH(float temperature) {
 return getSensorRH() / (1.0546 - (0.00216 * temperature));
// Read value from the sensor and convert to voltage value
float HIH4030::vout() {
 return (float)(analogRead(pin)) * supply / 1023;
wenn du in deinem Code noch STRG-T drückst und dich von den _ in den Variablen trennst ist es fast nicht mehr wieder zu erkennen :wink:
Die Konstante 5 würde ich noch kontrollieren, ob du an deinem 5V Pin wirklich 5V hast. Ich mein, wenn sonst mit 5 Nachkomma gerechnet wird, dann kann man sich das auch noch antun.
