I have a Mega with an Adafruit Datalogging shield and using a 3.5 TFT touch screen. On the TFT display is an SD card that I have a bit map that I load in as a background on the display. All of that is working. I had a second sketch that worked to datalog info but that sketch did not use the TFT. I am now trying to incorporate the datalogging shield which also has an SD card into the sketch that has the TFT. I am getting some errors. I believe the first couple of errors were because both sketches use "SD" to define the cards. So I changed the ones that are for the TFT card to "SD_TFT" I did notice that in the lines that I changed, "Adafruit_ImageReader reader(SD_TFT)" for example, that "SD" was red and now that I've changed it it is not.
So now when I compile I get the following error.
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino:10:0:
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:23:0: warning: "FILE_READ" redefined
#define FILE_READ O_READ
In file included from C:\Users\lampo\Documents\Arduino\libraries\SdFat\src/FatLib/FatLib.h:27:0,
from C:\Users\lampo\Documents\Arduino\libraries\SdFat\src/SdFat.h:33,
from C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino:7:
C:\Users\lampo\Documents\Arduino\libraries\SdFat\src/FatLib/ArduinoFiles.h:37:0: note: this is the location of the previous definition
#define FILE_READ O_RDONLY
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:24:0: warning: "FILE_WRITE" redefined
#define FILE_WRITE (O_READ | O_WRITE | O_CREAT | O_APPEND)
C:\Users\lampo\Documents\Arduino\libraries\SdFat\src/FatLib/ArduinoFiles.h:39:0: note: this is the location of the previous definition
#define FILE_WRITE (O_RDWR | O_CREAT | O_AT_END)
In file included from C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino:8:0:
C:\Users\lampo\Documents\Arduino\libraries\Adafruit_SPIFlash\src/Adafruit_SPIFlash.h:75:26: warning: integer overflow in expression [-Woverflow]
SFLASH_BLOCK_SIZE = 64*1024,
C:\Users\lampo\Documents\Arduino\libraries\Adafruit_SPIFlash\src/Adafruit_SPIFlash.h:75:27: warning: overflow in constant expression [-fpermissive]
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:62:3: error: 'SdVolume' does not name a type
SdVolume volume;
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:70:33: error: 'SD_CHIP_SELECT_PIN' was not declared in this scope
boolean begin(uint8_t csPin = SD_CHIP_SELECT_PIN);
Eoflow_Demo:69:1: error: reference to 'File' is ambiguous
File logfile;
C:\Users\lampo\Documents\Arduino\libraries\SdFat\src/FatLib/ArduinoFiles.h:122:7: note: candidates are: class File
class File : public FatFile, public Stream {
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:28:7: note: class SDLib::File
class File : public Stream {
C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino: In function 'void setup()':
Eoflow_Demo:189:7: error: 'logfile' was not declared in this scope
logfile = SD.open(filename, FILE_WRITE);
C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino: In function 'void loop()':
Eoflow_Demo:347:13: error: 'Pump_Test' was not declared in this scope
Pump_Test();
C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino: In function 'void drawHomeScreen()':
C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino:393:48: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
stat = reader.drawBMP("/logo2.bmp", tft, 0, 0);
C:\Users\lampo\Documents\Arduino\EoFlow\Eoflow_Demo\Eoflow_Demo.ino: In function 'void ReadBatt()':
Eoflow_Demo:628:1: error: a function-definition is not allowed here before '{' token
Pump_Test:2:1: error: a function-definition is not allowed here before '{' token
Pump_Test:95:1: error: expected '}' at end of input
} // end void Pump_Test
exit status 1
option enabled in File -> Preferences.
I've exceeded the number of characters allowed so I can only but the definitions I think apply here and part of the void setup.
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_HX8357.h"
#include "TouchScreen.h"
#include <SdFat.h> // SD card & FAT filesystem library
#include <Adafruit_SPIFlash.h> // SPI / QSPI flash library
#include <Adafruit_ImageReader.h> // Image-reading functions
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
// These are 'flexible' lines that can be changed
#define TFT_CS 26
#define TFT_DC 27
#define SD_CS 24
#define TFT_RST -1 // dont use a reset pin, tie to arduino RST if you like
//#define TFT_RST 8 // RST can be set to -1 if you tie it to Arduino's reset
SdFat SD_TFT; // SD card filesystem
Adafruit_ImageReader reader(SD_TFT); // Image-reader object, pass in SD filesys
Adafruit_Image img; // An image loaded into RAM
int32_t width = 480, // BMP image dimensions
height = 320;
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void setup(void) {
// The Adafruit_ImageReader constructor call (above, before setup())
// accepts an uninitialized SdFat or FatFileSystem object. This MUST
// BE INITIALIZED before using any of the image reader functions!
Serial.print(F("Initializing filesystem..."));
#if defined(USE_SD_CARD)
// SD card is pretty straightforward, a single call...
if(!SD_TFT.begin(SD_CS, SD_SCK_MHZ(25))) { // ESP32 requires 25 MHz limit
Serial.println(F("SD begin() failed"));
for(;;); // Fatal error, do not continue
#else
// SPI or QSPI flash requires two steps, one to access the bare flash
// memory itself, then the second to access the filesystem within...
if(!flash.begin()) {
Serial.println(F("flash begin() failed"));
for(;;);
if(!filesys.begin(&flash)) {
Serial.println(F("filesys begin() failed"));
for(;;);
#endif
Serial.println(F("OK!"));
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
// error("Card failed, or not present");
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
break; // leave the loop!
Thanks so much for any help
John
