I have a file _init.pde:
* digital i/o pin assignment
* this uses the undocumented feature of Arduino - pins 14-19 correspond to analog 0-5
//cartesian bot pins
#define X_STEP_PIN 2
#define X_DIR_PIN 3
#define X_MIN_PIN 4
#define X_MAX_PIN 9
#define X_ENABLE_PIN 15
then I would use this in StepperTest:
* Stepper
* http://www.arduino.cc/
int dirPin = 9;
int delayTime = 250;
int ledPin = 13;
int input;
void setup() // run once, when the sketch starts
pinMode(X_STEP_PIN, OUTPUT); // sets the digital pin as output
pinMode(dirPin, OUTPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(dirPin, HIGH);
Serial.println("hei");
void loop() // run over and over again
input = Serial.read();
if(Serial.available()>0){
Serial.println("duude");
if(input==65){
digitalWrite(ledPin, HIGH);
if(input==66){
digitalWrite(dirPin, LOW);
digitalWrite(ledPin, LOW);
Serial.println(input);
digitalWrite(stepPin, HIGH); // sets the step pin high
delayMicroseconds(delayTime); // waits for a given time
digitalWrite(stepPin, LOW); // sets the LED off
delayMicroseconds(delayTime*1.5); // waits for a given time
then i am getting this error:
In function 'void setup()':
error: 'X_STEP_PIN' was not declared in this scope In function 'void loop()':
What am I doing wrong?
I would also like to modify the code to use the arrow keypad to test the stepper. Up= increase speed, Down = decrease speed, Left= turn clockwise , right = turn anti clockwise.
I guess this would be a nice sketch for people that just want to test their stepper motor...
Maybe later also add The following input: G0 X15 Which can help u calibrating the movement of the stepper.
The idea is to have a simple sketch to just ensure that the stepper motor works the way its suppose to, and only for one axis,
than later u can use the reprap code..
Any comments??
