Defining data structure to build agenda
I’m not familiar with arduino, this is actually my first project. I’m trying to build an agenda of contacts, this contacts are within a txt file stored in a SD Card. So my idea is to read the file where each line represents a mobile number. For example if I want to call someone or send SMS I can use a GPRS shield and use AT Commands. There are quite a lot tutorials about this and it is pretty straight foward. So consider piece of code to send messages :
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM900
SoftwareSerial mySerial(7, 8); //SIM900 Tx & Rx is connected to Arduino #7 & #8
int iteration = 0;
  //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  //Begin serial communication with Arduino and SIM900
  mySerial.begin(9600);
  Serial.println("Initializing...");
  mySerial.println("AT"); //Handshaking with SIM900
  updateSerial();
  mySerial.println("AT+CMGF=1"); // Configuring TEXT mode
  updateSerial();
  mySerial.println("AT+CMGS=\"+ZZxxxxxxxxxxx\"");//change ZZ with country code and xxxxxxxxxxx with phone number to sms
  updateSerial();
  mySerial.print("Hello, I am Mr.Arduino"); //text content
  updateSerial();
  mySerial.write(26);
void updateSerial()
  while (Serial.available())
    mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
  while(mySerial.available())
    Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
I was wondering what’s the best way to build an agenda so I could for example send to a group of contacts… I know arduino does not have much memory, I read in few threads that String type is hard to work with and demands higher amounts of memory. So I would like opinions, since I am newbie. Which data structure would perform better for this case?
I tryed to work with char but ended up with erros like conversion from ‘const char*’ to ‘char’ [-fpermissive].
I’ll present another piece of code that represents what I first intend to do, this should merge with the above code when things get clearer
#include <SD.h>
#include <SPI.h>
File file;
// DECLARE DATA STRUCTURE HERE, to be defined with your help.
boolean SDfound;
int index = 0;
  if (SDfound == 0) {
    if (!SD.begin(53)) {
      Serial.print("The SD card cannot be found");
      while(1);
  SDfound = 1;
  file = SD.open("agenda.txt");
  if (!file) {
    Serial.print("The text file cannot be opened");
    while(1);
  while (file.available()) {
    DATASTRUCTURE[index] = printFile.readStringUntil('\n'); // Here i am storing the line content in a certain index within the data structure.
	index++;
  file.close();
   //empty
In possession of the agenda I could change the setup function of the first code to:
for(iteration=0;iteration<=sizeof(DATASTRUCTURE);i++){
	  updateSerial();
	  updateSerial();
	  mySerial.println("AT+CMGS=\""+DATATRUCTURE[iteration]+"\"");
	  updateSerial();
	  updateSerial();
	  mySerial.write(26);
I explained my idea, I still do not know if this is a good approach and due my deficiency in the language I do not know if it’s possible and will work, hopefully someone can give me some advice/piece of compatible code. Thanks !
don’t give up. working with char arrays is the way to go.
also it’s not an agenda you are building, looks more like an address book :slight_smile:
