Defining ranges with-in conditions
So this may be a very general question
If I wanted to define a range within a condition such as an IF statement how would that be written?
I understand how to use it with Greater than or less then etc.
Basically I'm using a potentiometer and would like an action to occur IF the range of 512-678 ( as a example ) is met.
sorry for the basic question. appreciate the help in advance.
-S
Using switch case with ellipses instead of if. Note the space before the first '.' and after the third '.'
switch(analoReadval)
   case(0 ... 100):
      //do something
   case(101 ... 200):
      //do something
// and so on
template<typename T>
inline bool is_value_in_range(T value, T value_min, T value_max)
    return ((value >= value_min) ? ((value <= value_max) ? true : false) : false);
Serial.println(is_value_in_range(11, 5, 10));
Serial.println(is_value_in_range(7, 5, 10));
All three values should be of the same sign type.
Or the simple solution
if (x>600 && x< 700)
    its in the range
} else
    it's not in the range
Mark
