Definition of Processor Type
For the Duemillenove w/328P, I have poked around in all sorts of dark corners trying to establish how and under what circumstances the symbol:
AVR_ATmega328P
actually gets #defined.
I've searched all of the *.h files on my machine, and I've looked in the preferences.txt file in the Arduino folder under Documents and Settings\Application Data without discovering any obvious mechanism.
Since the IDE invokes avr-gcc, does it pass the processor type as a command line argument which in turn defines the aforementioned symbol?
If that is indeed the case; is there a simple way to change that default?
Yes. If you turn on "build.verbose=true" in your preferences file (manually, with a text editor), you'll get to see the actual commands, which will look like:
hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -I/Applications/arduino/arduino-0016/hardware/cores/arduino -I/Applications/arduino/arduino-0016/hardware/libraries/Servo /Applications/arduino/arduino-0016/hardware/cores/arduino/Print.cpp -o/tmp/build7298.tmp/Print.cpp.o
Well, you can switch between mega8, mega168, and mega328 by changing the "board" selection in the Tools menu. Beyond that things get more complicated. (The next step is editing hardware/boards.txt ...)
Thanks for those two answers. They should keep me off the streets for at least a couple of hours anyway.
