Degree symbol - GLCD with KS0108 driver
Hello,
please is any known way (easy) how to display a degree symbol (for measuring the temperature) in 128x64 GLCD with KS0108 driver (using glcd library). With LCD 16x2 I was using the LCD.print((char)223) command. The intensive google search was not very helpful :frowning:
Thank you
With most glcd libraries printing a degree symbol is very easy,
just print the code value in the font for the degree symbol.
However, the ks0108 module has no built in fonts.
The fonts are implemented in the s/w so you will need to use a font that includes
a degree symbol.
Depending on which library you have it may or may not include a font with a degree symbol.
Also depending on which library you have, you may be able to define custom fonts.
The bottom line is you need to use a font that includes a degree symbol.
If the library doesn't include a font with a degree symbol, you may be able
to create a new font that includes one.
In the absence of being able to use a font with a degree symbol, you could
define a bitmap or even draw the pixels.
--- bill
