I've been working on a simple Arduino project where a button press will activate a 25 hour timer countdown before a servo turns 90 degrees. I'm a chemist and my idea was to automate an addition funnel valve to open up in the middle of the night or whenever I can't be there to turn the valve myself.
I also added program lines to make the onboard LED remain on during the timer count down and then blink once the servo turns for a visual que that everything worked as expected. This is my code.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int buttonPin = 2; // the pin that the button is attached to
int buttonState = 0; // variable for reading the button status
int buttonPressed = 0; // variable to track if the button has been pressed
int servoPosition = 0; // variable to track the current position of the servo
const int ledPin = 13;
const unsigned long SECOND = 1000;
const unsigned long HOUR = 3600 * SECOND;
myservo.attach(9); // attached the servo to pin 9 to the servo object
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP); // sets the button pin as an input with internal pull-up resistor
myservo.write(servoPosition); // move servo to the 0 degree at startup
digitalWrite(ledPin, LOW);
while (buttonPressed == 1 && servoPosition == 64) {
digitalWrite(ledPin, LOW); // turn the LED on
delay(1000); // wait for 1 second
digitalWrite(ledPin, HIGH); // turn the LED off
buttonState = digitalRead(buttonPin); // read the state of the button - put your main code here, to run repeatedly:
if (buttonState == LOW && buttonPressed == 0) { //if the button is pressed and not already pressed
buttonPressed = 1; // set the buttonPressed variable to 1 to indicate the button has been pressed
delay(25 * HOUR); // wait for 3 hours 10800000, 10 seconds 10000, 3600000/hr, 93600000/26hr
servoPosition = 64; // set the servo position to 90 degrees
myservo.write(servoPosition); // move servo to 90 degrees
This program works perfect on my Arduino Uno. However, the cheap Arduino Nano Every clones will not carry out the full 25 hour delay function. I keep coming back after ~ an hour to find the servo has turned early and the board's LED blinking.
During troubleshooting, I even changed the delay to 10 seconds, tested the program, everything worked as expected, and then reuploaded the program with the full 25 hour delay just to have the same result as before.
Any ideas why the program on the UNO works fine but the program on the NANO Every comes up short?
My first guess would be crystal variations and the associated effect on timers and timing: a 1% difference in frequencies could result in a difference of 160,000 clock cycles.
You are talking about controlling a process down to the millisecond, where you are counting 90 million of those milliseconds. These devices just are not precision instruments.
What would be the fix if it is a compiler bug? I have had problems getting the IDE to successfully upload the program. I usually have to try hitting upload several times before the upload goes through, or at least says its complete. I calked is up to a busy COM connection.
Or you could try using the BlinkWithoutDelay example sketch changing
const long interval = 1000; //for
unsigned long interval = 90000000;
(not tested )
