delay 5s when communicate serial port to transmit IR.
My project is control helicopter by kinect (processing), first time, i try to transmit IR for motor board . When i post a symbol to IR transmiter board, i see it delay 5s.
But, i used Serial Monitor to send a symbol and it has no delay.
then i use kinect to send the symbol to control motor board and it has no delay.
I think the problem on my IR transmiter code.
Please help me and thank you.
This is my code:
arduino ir transmiter
#define RED 4
#define led 7
int incomingByte = 0;
int throttleCmd = 0;
char cmd;
pinMode(RED, OUTPUT);
pinMode(led, OUTPUT);
 if (Serial.available()) {
  cmd = Serial.read();
 //===================================     IF =================================
  if (cmd == 'a')  {digitalWrite(led,HIGH);Transmit(10);}
 else if (cmd == 'b')  {digitalWrite(led,LOW);Transmit(20);}
 else if (cmd == 'c')  {digitalWrite(led,HIGH);Transmit(30);}
 else if (cmd == 'd')  {digitalWrite(led,LOW);Transmit(40);}
void Transmit(byte rudder) {
static byte Code[1];
byte mask = 128;         //bitmask
int i;
Code[0] = rudder; // 0 -> 127; 63 is the midpoint.
OutPulse(2002);  // Start 38Khz pulse for 2000us (2002us is evenly divided by 26)
delayMicroseconds(2000);  // 2000us off.
                    // Loops through the Code[i]
for (mask = 128; mask > 0; mask >>=1) {         // See Arduino reference for bit masking (really cool stuff!)
OutPulse(312);                     // Sends 312 pulse each loop
if(Code[0] & mask) {          //If both bit positions are 1 you get 1
delayMicroseconds(688);     // send 1 (700 off)
else {
delayMicroseconds(288);     // send 0 (300 off)
} //End mask loop
OutPulse(312);  //Send 300 microsecond Closing Pulse
delay(60);
} // End Transmit
void OutPulse(int Pulse) {  //sends 38Khz pulses over the Pulse Length
int p;
for(p = 0; p < (Pulse / 26) - 1; p++) {  //Takes about 26 microseconds per loop
digitalWrite(RED, HIGH);
delayMicroseconds(10);
digitalWrite(RED, LOW);
}  //End OutPulse
You have 4 seconds delay in your code - might that be the problem?
This Thread may be of interest.
...R
thank you, ít's helpful :slight_smile: :slight_smile: :slight_smile: :slight_smile:
