delay after ISR not working
Hello,
i have an ISR that sets a flag=true on a button press and returns control to the program, there’s a IF test for the flag that disables interrupts, sets some outputs high, then waits for 10s sets low, clears the flag, reenables interrupts and continues main loop…
problem is that the delay is not working, i activate the interrupt, i get the serial output and instantly the program continues, delay completely ignored…
Whys is this happening?, i’m not inside the ISR so delay should be working, i tried some ridiculous value for delay like 10000 and more and still gets ignored (outputs cycle high and a fraction of a sec later go low).
here’s the entire code for completeness:
 pines:
 Pin 2 - input: Reset (interrupt 0)
 Pin 3 - input: SLO
 Pin 4 - output LED: Cargando
 Pin 5 - output: Rele
v8 8/2
// Constantes globales y definicion pines
const byte SLO = 3;
const byte ledcharge = 4;
const byte rele = 5;
const byte reset = 2;
const long tiempo_en_prueba = 300000;  //15 min tiempo en prueba 900Kmsec, usar 300K para 5 min
const int tiempo_fraccion = tiempo_en_prueba/1000; //Para fraccionar los delays largos en el ejercicio
const unsigned long tiempo_para_ejercitar = 600000; //20min hasta testear, en realidad tiene que ser 1209600000(2 semanas)
unsigned long fin_retardo = 0; //inicializo fin delay
boolean contando = false; //inicializo sin contar
volatile boolean reset_flag = false; //no esta reseteado
byte slo_state; //inicializo variable para el SLO
void setup(){
  pinMode(SLO, INPUT);
  pinMode(rele, OUTPUT);
  pinMode(ledcharge, OUTPUT);
  attachInterrupt(0, reset_event, CHANGE);
void loop(){
posicion_inicio:
  if (reset_flag == true){
    noInterrupts();
    fin_retardo = 0; //inicializo vars
    contando = false;
    digitalWrite (rele, HIGH); //activar rele
    digitalWrite (13, HIGH); // debug
    digitalWrite(ledcharge,LOW);
    Serial.println("Reset!!!!!!"); //debug
    delay(4000);
    digitalWrite (rele, LOW); //desactivar rele
    digitalWrite (13, LOW); //debug
    reset_flag = false; //termino reset
    interrupts();
  slo_state = digitalRead (SLO); //leer pin SLO, recordar que esta negado
  if ((slo_state == LOW) && (contando == false)){ //esta en float, no estoy testeando carga y aún no estoy contando para testear
    unsigned long currenttime = millis();
    fin_retardo = currenttime + tiempo_para_ejercitar; // fin retardo, tiempo actual+diff tiempo hasta ejercitar
    Serial.print("el fin del delay es: "); //debug
    Serial.println(fin_retardo); //debug
    Serial.println(currenttime); //debug
    contando = true; //Empieza el conteo regresivo a la ejercitacion
  else if (slo_state == HIGH && contando == true){
    contando = false; //Si mientras cuento se va de flote, abortar cuenta
  if (slo_state == HIGH) {                // si no esta a flote, encender led de carga
    digitalWrite(ledcharge,HIGH);
  else digitalWrite(ledcharge,LOW);      // si esta a flote, apagarlo
  Serial.print("la diferencia actual es: ");  //debug
  Serial.println((long)( millis() - fin_retardo )); //debug
  if (contando == true)  Serial.println("contando"); //debug
  delay(1000); //debug
  if ((contando == true) && ((long)( millis() - fin_retardo ) >= 0)){ //Si termino la cuenta regresiva empezar a ejercitar
    contando = false; //termino la cuenta regresiva
    for(byte l = 0; l < 4; l++){  // 4 loops de ejercitacion(0 a 3)
      if (reset_flag == true) goto posicion_inicio; //abortar si reset
      Serial.print("Testeando! loop: "); //debug
      Serial.println(l,DEC); //debug
      //comienzo delay sintetizado
      for (int i = 0; i < 1000; i++) {
        delay (tiempo_fraccion);
      } //fin delay sintetizado
      Serial.println("Descansando!"); //debug
      //comienzo delay sintetizado half
      for (int i = 0; i < 500; i++) {
    } //fin loop ejercitacion
void reset_event(){
  reset_flag = true; //set reset
disables interrupts
delay / millis / micros do not "run" when interrupts are disabled.
:astonished: i knew that and for some reason when i thought of disabling interrupts i got focused on EXTERNAL interrupts and forgot about delay using it... arghh... fixing.... yeahp, that did the trick, thanks a lot :* :*
i could disable and then reenable before the delay and again after that to get a level of protection against unwanted interrups(but i dont thik it's really necessary)
