Delay between a sensor and solenoid
I'm making a watering system which uses a sensor a to turn on the solenoid valve and i have ran into a few issues:-
  1. The sensor cannot be constantly measuring so i need a cooling off period
  2. I need the solenoid needs to turn for some time and then turn off.
    Please send some examples of code since it is easier to understand.
Haze_20:
Please post your best attempt at the code to get some help. If you want someone to write code for you then you can hire someone in the Gigs and Collaborations forum.
