Delay function not accurate enough: use of mills?
Hi guys,
I have a function that needs to execute every n microseconds.
If I have
Void loop{
delay(200);
My function;
And myfucntion takes 100ms to complete then each loop will be 300ms. Not good.
How can I use the millis function to ensure the delay is taking into consideration the time it takes for myfucntion to complete?
Basically I need myfunction to start every 200ms regardless of the time it takes myfunction to complete. (obviously if myfunctiom takes more than 200ms I'll have problems but it's usually taking 2-3 to complete.
Cheers in advanced.
You could use my elapsed time class:
That way you do something after a specific time has elapsed.
MyFunction without delay ....
#define THRESHOLD  200
unsigned long lastTime = 0;
  Serial.println("Start...");
  if (millis() - lastTime >= THRESHOLD)
    lastTime = millis();
    MyFunction();
void MyFunction()  // replace by your own ..
  Serial.println(lastTime );
-- update --
Below there are some serious improvements (subtile but serious)
I've never liked the idea of calling millis() twice like this, since it is possible to get two different values.
unsigned long thisTime = millis();
if(thisTime - lastTime >= THRESHOLD)
    lastTime = thisTime;
This makes only one call to millis(), at the cost of 4 extra bytes on the head.
Definitely better to use the var thisTime as timing would indeed creep forward, thanks
For more accurate timing use this:
unsigned long lastTime;
  Serial.begin("Start...");
    lastTime += THRESHOLD
    MyFunction();
If you want to execute MyFunction immediately the first time loop() is called instead of waiting for THRESHOLD ms, then initialize lastTime to millis() - THRESHOLD instead in setup().
OK I see the difference, it is subtile but relevant ,
This variation should be documented too at the famous - http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay - Tutorial
Thanks dc42, still learning everyday :slight_smile:
