thanks everyone for your suggestions now everything is working fine with external crystal @ 4Mhz, except one thing
PROBLEM:
i am still unable to upload the program using Serial programmer
although the steps i followed are as below
to make delay work, i changed my wiring.c to this
/* Delay for the given number of microseconds. Handles 20, 16, 8 or 4 MHz clock */
/* The 20 MHz change was in V1.0.1, the 4 MHz is my unofficial change. */
void delayMicroseconds(unsigned int us)
// calling avrlib's delay_us() function with low values (e.g. 1 or
// 2 microseconds) gives delays longer than desired.
//delay_us(us);
#if F_CPU >= 20000000L
// for the 20 MHz clock on rare Arduino boards
// for a one-microsecond delay, simply wait 2 cycle and return. The
// overhead of the function call yields a delay of exactly 1 microsecond.
__asm__ __volatile__ (
"nop" "\n\t"
"nop"); //just waiting 2 cycle
if (--us == 0)
return;
// the following loop takes a 1/5 of a microsecond (4 cycles)
// per iteration, so execute it five times for each microsecond of
// delay requested.
us = (us<<2) + us; // x5 us
// account for the time taken in the preceeding commands.
us -= 2;
#elif F_CPU >= 16000000L
// for the 16 MHz clock on most Arduino boards
// for a one-microsecond delay, simply return. the overhead
// of the function call yields a delay of approximately 1 1/8 us.
if (--us == 0)
return;
// the following loop takes a quarter of a microsecond (4 cycles)
// per iteration, so execute it four times for each microsecond of
// delay requested.
us <<= 2;
us -= 2;
#elif F_CPU >= 8000000L
// for the 8 MHz internal clock on the ATmega168
// for a one- or two-microsecond delay, simply return. the overhead of
// the function calls takes more than two microseconds. can't just
// subtract two, since us is unsigned; we'd overflow.
if (--us == 0)
return;
if (--us == 0)
return;
// the following _asm_ loop takes 4 cycles (half a microsecond at 8 MHz)
// per iteration, so execute it twice for each microsecond of
// delay requested.
us <<= 1;
// partially compensate for the time taken by the preceeding commands.
// we can't subtract any more than this or we'd overflow w/ small delays.
us--;
#else
// For the 4 MHz case: Do not change us.
// for a 1 microsecond delay, simply return. The overhead of
// the function calls takes more than four microseconds.
if (--us == 0)
return;
// the following _asm_ loop takes 4 cycles (one microsecond at 4MHz)
// per iteration, so execute once for every microsecond of the argument.
#endif
// busy wait
"1: sbiw %0,1" "\n\t" // 2 cycles
"brne 1b" : "=w" (us) : "0" (us) // 2 cycles
the delay is working fine now if i upload the program through usbasp.
since i did a change in boards.txt for serial programming given below
pAvaR6LP.name=pAVA R6 Low Power (4 MHz) w/ ATmega328
pAvaR6LP.upload.protocol=arduino
pAvaR6LP.upload.maximum_size=30720
pAvaR6LP.upload.speed=28800
pAvaR6LP.bootloader.tool=arduino:avrdude
pAvaR6LP.upload.tool=avrdude
pAvaR6LP.bootloader.low_fuses=0xFF
pAvaR6LP.bootloader.high_fuses=0xDE
pAvaR6LP.bootloader.extended_fuses=0x05
pAvaR6LP.bootloader.path=optiboot
pAvaR6LP.bootloader.file=optiboot_atmega328.hex
pAvaR6LP.bootloader.unlock_bits=0x3F
pAvaR6LP.bootloader.lock_bits=0x0F
pAvaR6LP.build.mcu=atmega328p
pAvaR6LP.build.f_cpu=4000000L
pAvaR6LP.build.core=arduino
pAvaR6LP.build.variant=standard
Program does not upload and gives an error messages
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b28800 -D -Uflash:w:C:\Users\VAADYA01\AppData\Local\Temp\build7173828598596770212.tmp/sketch_jun24a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 28800
avrdude: serial_baud_lookup(): Using non-standard baud rate: 28800 AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
firstly i uploaded arduino UNO bootloader (optiboot selecting uno board) and then i used my board (pAVA R6 Low Power) with 1/4th of uno's upload speed (28800) but still i am unable to upload my program using serial programmer yet i am getting an error message given above.
please help me.
