delay function parameter minimum
Is zero a valid parameter for delay functions. just need simple yes or no. Did not see parameter minimum in reference.
If you look at the course code in wiring.c, passing in a 0 for the parameter should cause no issues.
jcebyjr:
What happened when you tried it?
...R
Robin2:
Easier to ask....
When in doubt . . .
void delay(unsigned long ms)
	uint16_t start = (uint16_t)micros();
	while (ms > 0) {
		if (((uint16_t)micros() - start) >= 1000) {
			ms--;
			start += 1000;
JimboZA:
Robin2:
Easier to ask....
Not really. Not at all.
AWOL:
When in doubt . . .look at the source code
...R
And the source code tells us that:
  • delay() is unsigned long so 0 is a valid argument void delay(unsigned long ms)
  • But 0 has no effect (as one would expect) because of while (ms > 0) {
