Your code was small enough to simply post here:
#include <AFMotor.h>
AF_DCMotor Motor1(1);
int speed = 0; //preset the speed to 0
const int IRD_A = 22; //Infrared detector at track end North
const int IRD_B = 23; //Infrared detector at track end South
const int LED = 53; //Indicates detector trip
const int Speed_Pot = A13; //potentiometer for Speed control of train motion
const int Delay_Pot = A15; //potentiometer for Delay control of train motion
boolean ignore_detector_a = false; //Set IRD to FALSE to start
boolean ignore_detector_b = false; //SET IRD to FALSE to start
int Speed_val = 0; //Clear the Speed_val variable
int Delay_val = 0; //Clear the Delay variable
int Speed_val_C = 25;
pinMode (IRD_A, INPUT); //IRD pin set to INPUT
pinMode (IRD_B, INPUT); //IRD pin set to INPUT
pinMode (LED, OUTPUT); //LED pin set to OUTPUT
pinMode (Speed_Pot, INPUT); //Speed potentiometer pin set to INPUT
pinMode (Delay_Pot, INPUT); //Speed potentiometer set to INPUT
digitalWrite(22, LOW); //Reset IRD pin to LOW
digitalWrite(23, LOW); //Reset IRD pin to LOW
//Speed_val_C = (Speed_val, Speed_val <= 24, Speed_val = 25);
Speed_val = analogRead(Speed_Pot); //Read the Delay_Pot to obtain the Speed_val
Delay_val = analogRead(Delay_Pot); //Read the Delay_Pot to obtain the delay_val
Serial.println(Speed_val_C);
// Read the Infrared detectors, If the A is blocked and B is not blocked, Stop the train (RELEASE, BRAKE),
// Delay the direction change by the Delay_val, then send train North (SetSpeed, FORWARD)
int ir_detected = LOW;
if (!ignore_detector_a) {
ir_detected = digitalRead(IRD_A);
if (ir_detected) {
ignore_detector_a = true;
Motor1.run(RELEASE);
Motor1.run(BRAKE);
delay(Delay_val * 30);
speed = Speed_val/4 ;
Motor1.setSpeed (speed) ;
Motor1.run(FORWARD);
// Read the Infrared detectors, If the B is blocked and A is not blocked, Stop the train (RELEASE, BRAKE),
// Delay the direction change by the Delay_val, then send train South (SetSpeed, FORWARD)
} else if (!ignore_detector_b) {
ir_detected = digitalRead(IRD_B);
if (ir_detected) {
ignore_detector_b = true;
Motor1.run(BRAKE);
Motor1.run(BACKWARD);
Changing from delay() to millis() is not just a matter of switching a couple of lines of code. It is a matter, in this case, of completely rewriting the program. On any given pass through loop(), the program is in some state (train is moving, train is stopped, etc.). There may be things that have changed since the last pass through loop(), such as a user pressing a switch, the train having blocked a sensor, or having unblocked one, that change what state the program is in. Enough time might have passed (the train stopped for three seconds) that a change in state is warranted.
You need to separate the change detection code from the change transition code and the what do I do in this state code. Your code will look like this:
int state;
detectStateChanges();
implementStateChange();
implementState();
I think it should be fairly apparent which part of the existing code goes in which function.
Using an enum to assign names to states makes it more obvious what each state means, rather than using an int, but if you document what each state number means, in a small application it doesn't really matter.
