Hello all,
I am using arduino due to create waveform generator. When I was referring the code of simplewaveform generator, here I came across delayMicroseconds. Why it has used? Is it to modify the frequency of the wave? The code is as follows
#include "Waveforms.h"
#define oneHzSample 1000000/maxSamplesNum // sample for the 1Hz signal expressed in microseconds
const int button0 = 2, button1 = 3;
volatile int wave0 = 0, wave1 = 0;
int i = 0;
int sample;
analogWriteResolution(12); // set the analog output resolution to 12 bit (4096 levels)
analogReadResolution(12); // set the analog input resolution to 12 bit
attachInterrupt(button0, wave0Select, RISING); // Interrupt attached to the button connected to pin 2
attachInterrupt(button1, wave1Select, RISING); // Interrupt attached to the button connected to pin 3
// Read the the potentiometer and map the value between the maximum and the minimum sample available
// 1 Hz is the minimum freq for the complete wave
// 170 Hz is the maximum freq for the complete wave. Measured considering the loop and the analogRead() time
sample = map(analogRead(A0), 0, 4095, 0, oneHzSample);
sample = constrain(t_sample, 0, oneHzSample);
analogWrite(DAC0, waveformsTable[wave0][i]); // write the selected waveform on DAC0
analogWrite(DAC1, waveformsTable[wave1][i]); // write the selected waveform on DAC1
i++;
if(i == maxSamplesNum) // Reset the counter to repeat the wave
i = 0;
delayMicroseconds(sample); // Hold the sample value for the sample time
// function hooked to the interrupt on digital pin 2
void wave0Select() {
wave0++;
if(wave0 == 4)
wave0 = 0;
// function hooked to the interrupt on digital pin 3
void wave1Select() {
wave1++;
if(wave1 == 4)
wave1 = 0;
