Delay is required for running DhcpAddressPrinter on Due
Hi all,
just sharing my experience here. Due won't print anything unless you
add Delay() after serial.begin()
as stupid as it sounds, this info might help others.
BR
Owen
  // this check is only needed on the Leonardo:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for (;;)
  // print your local IP address:
  Serial.println("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.println(Ethernet.localIP()[thisByte], DEC);
    Serial.println(".");
  while(1);
