Hi there,
I have some code i am working on for the Atmega328 and for some reason i just cannot get the delay to work at a certain point, i dont know if one of my libraries are conflicting with delay or if there is something silly i am missing? Here is the full code:
#include <SimpleFOC.h>
const int statusLED = 4; // Define the pin for the LED
// NeoPixel settings
#define NUM_PIXELS 7 // Number of NeoPixels
#define NEOPIXEL_PIN A3 // Pin connected to the NeoPixels
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_PIXELS, NEOPIXEL_PIN, NEO_GRB + NEO_KHZ800);
// Rotary encoder pins
const int encoderPinA = A1; // Output A
const int encoderPinB = A2; // Output B
// Rotary encoder click pin
const int encoderClickPin = A0;
// Sensor input pin
const int sensorPin = 2; // Replace with the actual pin number
// LED colors
uint32_t blueColor = strip.Color(0, 0, 255); // Blue color
uint32_t redColor = strip.Color(255, 0, 0); // Red color
int neoPixelBrightness = 50; // Adjust brightness (0 to 255)
// Variables to control the number of LEDs lit up
int blueNumLedsLit = 7; // Number of LEDs lit up for the blue page
int redNumLedsLit = 7; // Number of LEDs lit up for the red page
int encoderState = LOW; // Initialize encoder state
// Variables to track the current page
int currentPage = 0; // 0 for blue, 1 for red
// BLDC motor & driver instance
BLDCMotor motor = BLDCMotor(7);
BLDCDriver6PWM driver = BLDCDriver6PWM(5, 6, 9, 10, 3, 11);
// Target variable
float target_velocity = 6;
// Sensor state
bool sensorTriggered = false;
// Set the LED pin as an output and turn it on
pinMode(statusLED, OUTPUT);
digitalWrite(statusLED, HIGH);
// NeoPixel initialization
strip.begin();
strip.show(); // Initialize all pixels to 'off'
strip.setBrightness(neoPixelBrightness); // Set the NeoPixel brightness
// Initialize to the blue page
setNumLedsLit(blueNumLedsLit, blueColor);
// Driver config
driver.voltage_power_supply = 5;
driver.voltage_limit = 5;
driver.pwm_frequency = 32000;
driver.init();
motor.linkDriver(&driver);
// Limiting motor movements
motor.voltage_limit = 3;
// Open loop control config
motor.controller = MotionControlType::velocity_openloop;
// Init motor hardware
motor.init();
// Add target command T
Serial.println("Set color page");
void setNumLedsLit(int numLeds, uint32_t color) {
for (int i = NUM_PIXELS - 1; i >= 0; i--) { // Reverse loop order
if (i >= NUM_PIXELS - numLeds) {
strip.setPixelColor(i, color);
strip.setPixelColor(i, strip.Color(0, 0, 0)); // Turn off the remaining pixels
strip.show();
void swapPage() {
// Store the current value based on the current page
if (currentPage == 0) {
blueNumLedsLit = blueNumLedsLit;
redNumLedsLit = redNumLedsLit;
// Toggle the page
currentPage = 1 - currentPage;
// Set the number of LEDs based on the new page
setNumLedsLit(redNumLedsLit, redColor);
// Read the rotary encoder state
int newEncoderState = digitalRead(encoderPinA);
// Detect rotary encoder rotation
if (newEncoderState != encoderState) {
if (digitalRead(encoderPinB) != newEncoderState) {
// Clockwise rotation detected, increase the number of LEDs lit
blueNumLedsLit = min(NUM_PIXELS, blueNumLedsLit + 1);
redNumLedsLit = min(NUM_PIXELS, redNumLedsLit + 1);
// Counter-clockwise rotation detected, decrease the number of LEDs lit
blueNumLedsLit = max(0, blueNumLedsLit - 1);
redNumLedsLit = max(0, redNumLedsLit - 1);
// Handle the encoder click button to swap pages
int buttonState = digitalRead(encoderClickPin);
static int lastButtonState = LOW;
if (buttonState != lastButtonState) {
if (buttonState == HIGH) {
swapPage();
delay(50); // Debounce delay
// Read the sensor state
sensorTriggered = digitalRead(sensorPin) == LOW;
// Save the current button state and encoder state
lastButtonState = buttonState;
encoderState = newEncoderState;
// Control the motor speed based on the blue and red LED maps respectively
float mappedVelocity = map(blueNumLedsLit, 0, NUM_PIXELS, 0, 20); // Adjust the range as needed
if (mappedVelocity < 1) {
mappedVelocity = 0;
float redMappedVelocity = map(redNumLedsLit, 0, NUM_PIXELS, 0, 1000); // Adjust the range as needed
if (redMappedVelocity < 1) {
redMappedVelocity = 0;
if (sensorTriggered) {
// Handle sensor logic (pause motor when sensor is triggered) and turn pixels red
motor.move(0);
setNumLedsLit(NUM_PIXELS, redColor);
// Add delay based on Red LEDS
motor.move(0);
delay(redMappedVelocity);
motor.move(mappedVelocity);
// If the sensor is not triggered, set the pixels based on the current page
// You can add code here for the red page functionality (e.g., adjusting the delay)
The part i am struggling with is here:
motor.move(0);
motor.move(0);
When the sensor is triggered the motor should stop and the lights go red, when the sensor is not triggered i need a delay before the motor starts again at the mapped speed. The delay is based on the map for the red LEDs.
I have also tried just having a number in there, or even using the other map as the delay and to no avail.
Please let me know if you need any more info and i will provide it. (Also fresh install of IDE this morning to make sure it wasnt that).
Any help is greatly appreciated!
-pobajobs
