Hi all,
I have a 8 hour delay in my program, but after 8 hours the stuff after the delay command is not executing!
Have I exceeded the delay time?
Section:
/* IF REBOOT ALL COMMAND RECEIVED */
if (req.indexOf("/OFFOVERNIGHT") != -1) { //checks if you clicked ON
WiFi.disconnect();
/* TURN ALL WIFI COMPONENTS OFF (RELAY NC)*/
digitalWrite(relay1, LOW);
digitalWrite(relay2, LOW);
digitalWrite(relay3, LOW);
digitalWrite(relay4, LOW);
Serial.println("Off Overnight");
/* DELAY 8 HOURS */
delay(offMilliseconds);
/* TURN THE WIFI COMPONENTS ALL BACK ON WITH A 30 SECOND DELAY (RELAY NC) */
digitalWrite(relay1, HIGH);
delay(delayTime);
digitalWrite(relay2, HIGH);
delay(delayTime);
digitalWrite(relay3, HIGH);
delay(delayTime);
digitalWrite(relay4, HIGH);
delay(60000); //wait for WiFi to come back up
ResetWiFi();
All code:
D1 = GPIO 5
D2 = GPIO 4
D3 = GPIO0
D4 = GPIO2
#include <ESP8266WiFi.h>
const char* ssid = "****"; //ssid
const char* password = "****"; //password
const char* host = "****"; //ESP8266 IP address
bool startServer = false; //varaible used to tell if the the server to restart if WiFi connection lost the connected
/* INITIALIZE RELAY PINS */
int relay1 = 5;
int relay2 = 4;
int relay3 = 0;
int relay4 = 2;
int delayTime = 30000; //delay between each relay turning on
unsigned long offMilliseconds = 28800000L; //delay for the "off overnight" function
WiFiServer server(301); //just pick any port number you like
/* BEGIN SERIAL */
delay(10);
/* SET OUTPUT PINS */
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
Serial.println("Reboot All");
delay(delayTime);
delay(delayTime);
delay(delayTime);
delay(delayTime);
/* CONNECT TO WIFI */
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password); //try to connect to WiFi
while (WiFi.status() != WL_CONNECTED) { //if not connected to WiFi
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
server.begin(); //start the server
Serial.println("Server started");
Serial.println(WiFi.localIP()); //print your IP
/* CHECK IF A CLIENT HAS CONNECTED */
WiFiClient client = server.available();
if (!client) {
return;
/* WAIT UNTIL THE CLIENT SENDS SOME DATA */
while (!client.available()) {
delay(1);
/* READ THE FIRST LINE OF THE REQUEST */
String req = client.readStringUntil('\r');
client.flush();
/* MATCH THE REQUEST */
if (req.indexOf("") != -10) { //checks if you're on the main page
/* IF REBOOT MODEM COMMAND RECEIVED */
if (req.indexOf("/REBOOTMODEM") != -1) { //checks if you clicked REBOOT MODEM
WiFi.disconnect();
Serial.println("Reboot Modem");
delay(delayTime);
ResetWiFi();
WiFi.disconnect();
/* DELAY 8 HOURS */
delay(delayTime);
delay(delayTime);
delay(delayTime);
ResetWiFi();
if (req.indexOf("/REBOOTALL") != -1) { //checks if you clicked ON
WiFi.disconnect();
delay(delayTime);
delay(delayTime);
delay(delayTime);
delay(delayTime);
ResetWiFi();
else {
Serial.println("invalid request");
client.stop();
return;
/* PREPARE THE RESPONSE */
String response = "HTTP/1.1 200 OK\r\n";
response += "Content-Type: text/html\r\n\r\n";
response += "<!DOCTYPE HTML>\r\n<html>\r\n";
response += "
<p style=' border: 2px dashed blue; vertical-align:center; text-align:center; color:blue; font-size:42px; margin: 20px 5px; padding: 30px 10px;'>Please close this window once you have selected an option!</p>";
response += "
response += "
<p style='text-align:center;'><input type=\"button\" style='text-align: center; font-size: 40px; width: 1000px; height: 70px; color: blue' name=\"rebootall\" value=\"Reboot All\" onclick=\"location.href='/REBOOTALL'\"></p>";
response += "
response += "
<p style='text-align:center;'><input type=\"button\" style='text-align: center; font-size: 40px; width: 1000px; height: 70px; color: blue' name=\"rebootmodem\" value=\"Reboot Modem\" onclick=\"location.href='/REBOOTMODEM'\"></p>";
response += "
response += "
<p style='text-align:center;'><input type=\"button\" style='text-align: center; font-size: 40px; width: 1000px; height: 70px; color: blue' name=\"offovernight\" value=\"Off Overnight (8 Hrs)\" onclick=\"location.href='/OFFOVERNIGHT'\"></p>";
response += "</html>\n";
client.flush();
/* SEND THE RESPONSE TO THE CLIENT */
client.print(response);
delay(1);
void ResetWiFi() {
Serial.print(".");
startServer = true;
if (startServer == true) {
Serial.println("");
Any help with this would be awesome because I'm stumped!
Thanks,
Zeb
