Delay of several if statements
Hello all
I am trying to find a possibility to be able to add timing to serveral if's.
One if statement should finish. The one after that should only start after a delay and the third one after the delay attributed to it.
I have written the following code. I don't find the reason why it doesn't work. I especially don't understand why the third statement appears at almost the same time as the second no matter what delay I attribute put.
long previousReset = 0;
bool one = false;
bool two = false;
  if( (millis() - previousReset >= 1000)
      && (one == false) && (two == false) ){
    previousReset = millis();
    Serial.println("first");
    one = true;
  if( (millis() - previousReset >= 3000)
      && (one == true) && (two == false) ){
    previousReset = millis;
    Serial.println("second");
    two = true;
    one = false;
  if( (millis() - previousReset >= 15000)
      && (two == true) && (one == false) ){
    Serial.println("third");
    two = false;
What better way is there to achieve this?
Thank you!
moses
In your second if statement you have
Instead of:
What is happening is the pointer to the function millis is being assigned to previousReset. Who knows what value that is...
i think switch statement for each case would be better. And calculate the time since the previous just once at the beginning, calling millis() just once.
unsigned long msec = millis();
unsigned long time = msec - previousReset;
static int state = 0;
swtich (state) {
case 0:
if (1000 < time) {
Serial.println ("first");
previousReset = msec;
state = 1;
the last case sets state back to 0.
I saw the title and thought "I hope this isn't full of delay();s. Thankfully not. For using millis(); ++Karma;
I get:
first
(delay)
second
(delay)
third
(short delay)
first
...etc
You don't need to use, for example:
one == true
or
one == false
just
one
on its own will do for true and
!one
for false.
You problem intrigued me but I am about to go out so cannot give it any more attention, sorry.
A more general method would be a state variable. That allows you to have many states with only one variable to keep track of.
unsigned long previousReset = 0;
byte state = 0;
  switch (state)
    case 0:
      if (millis() - previousReset >= 1000)
        state++;
    case 1:
      if (millis() - previousReset >= 3000)
        state++;
    case 2:
      if (millis() - previousReset >= 15000)
        state = 0;
Since all of your states do very much the same thing, using arrays would make sense here:
byte state = 0;
const char * StateNames[3] = {"first", "second", "third"};
const unsigned long StateDelays[3] = {1000, 3000, 15000};
const byte MaxState = 2;
  if (millis() - previousReset >= StateDelays[state])
    Serial.println(StateNames[state]);
    state++;
    if (state > MaxState)
      state = 0;
ToddL1962:
Instead of:
Oops! It's crazy I had a look at the code many times but it never caught my eye.
Thank you.
PerryBebbington:
I get:
first
(delay)
second
(delay)
third
(short delay)
first
...etc
one == true
or
one == false
just
one
!one
for false.
Thank you for the Karma and the advises...
gciurpita:
swtich (state) {
case 0:
if (1000 < time) {
state = 1;
What would be the advantage of the "precalculation"?
johnwasser:
byte state = 0;
  switch (state)
    case 0:
        state++;
case 1:
        state++;
    case 2:
        state = 0;
byte state = 0;
    state++;
      state = 0;
Thank you for the two ideas!
Well the example was more of a "prove of concept" kind of thing.
I like the idea of the arrays. I need to have a look if this approach would be possible.
Could someone tell me which is the correct / better way of writing if statements and others:
if (compare) {
do something
do something else
do another thing
or
if (compare)
do something
do something else
do another thing
Thank you
That depends on your definition of better. Personally I prefer the second style but with better indenting
if (compare)
  do something;
  do something else;
  do another thing;
The Auto formatting tool in the IDE can be configured to use this layout automatically
Thank you UKHeliBob
Does this mean there is no general rule of how to do it?
Is it a matter of preference?
moserroger:
it's good practice to avoid redundant code.
Yes. The compiler does not care about the layout of the code, only that the syntax is correct.
Similarly in the case of how variable names are written
Thank you again UKHeliBob
Now that we are talking about the blink without delay concept. I was wondering why I couldn't write the definition of the previous event in the loop part of the code. Why does it have to be in the header?
unsigned long previousmillis;
Thank you
moses
Try it.
You'll learn about local variables, scope, loop() as a function, and static variable qualifiers.
//unsigned long previousmillis;
static unsigned long previousmillis = 0;
Hello cattledog
Thank you for the reply.
So far I never really understood about static even though I read about it. May be it will be getting clearer now. I will read about it again.
Cheers,
moses
Is there anything that speaks against using delay() in setup()? I guess the interruption of the code are less problematic in setup()?
moserroger:
Feel free to use it if you want the program to do nothing for a period of time
moserroger:
Possibly because static has several different meanings, depending on the context it is used in. Read carefully :slight_smile:
