Delay on the display nextion
Hi
I'm making a system using ESP32, Nextion and mqtt connection.
I am using the ITEAD library for Nextion. It turns out that when I load the sketch on the board and turn on the display nextion on the power and TX2 / RX2, when I click on the home button (btnInit) to open the second page (pageSecond) I have a delay, sometimes as little as 2 seconds, but sometimes large (+ 10 seconds). And I only get the message mqtt (which is retained = true) after it arrives on the second page.
I can't figure out the reason for this, I suspect it's the loop () but I don't know what to do.
bool firstConnection = false;
const char* usermqtt = "esp32/fitest01";
#include <timeObj.h>
timeObj timeMax(30 * 1000.0); //30 seconds
#include <EEPROM.h>
#include <PubSubClient.h>
#include <SPIFFS.h>
#include <WiFiClient.h>
#include <ESP_WiFiManager.h>
#include <Nextion.h>
#include <WiFi.h>
#include "ArduinoJson.h"
NexButton btnInit = NexButton(0, 2, "b0");
NexButton btnBack = NexButton(1, 3, "btnVoltar");
NexPage pageInit = NexPage(0, 0, "page0");
NexPage pageSecond = NexPage(1, 0, "page1");
NexTouch *nex_listen_list[] =
  &btnInit,
  &btnBack,
  NULL
// SSID and PW for Config Portal
String ssid = "ESP_" + String(ESP_getChipId(), HEX);
const char* password = "your_password";
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
// Indicates whether ESP has WiFi credentials saved from previous session
bool initialConfig = false;
// Use true for dynamic DHCP IP, false to use static IP and  you have to change the IP accordingly to your network
#define USE_DHCP_IP     true
// Use DHCP
IPAddress stationIP   = IPAddress(0, 0, 0, 0);
IPAddress gatewayIP   = IPAddress(192, 168, 2, 1);
IPAddress netMask     = IPAddress(255, 255, 255, 0);
IPAddress dns1IP      = gatewayIP;
IPAddress dns2IP      = IPAddress(8, 8, 8, 8);
#define ESP_getChipId()   ((uint32_t)ESP.getEfuseMac())
#define PIN_LED 2
#define PIN D1
#define NUM_LEDS 3
bool shouldSaveConfig = false;
char placeWifi[60];
String nameOfPlace;
int numberOfPage;
const size_t JSON_SIZE = JSON_OBJECT_SIZE(1) + JSON_OBJECT_SIZE(9) + 4 * JSON_OBJECT_SIZE(17) + JSON_OBJECT_SIZE(18) + JSON_OBJECT_SIZE(20) + 2 * JSON_OBJECT_SIZE(21) + JSON_OBJECT_SIZE(23);
StaticJsonDocument<JSON_SIZE> docSpiffs;
const char* mqtt_server = "XXX.XXX.XXX.123";
WiFiClient wifiClient;
PubSubClient client(mqtt_server, 1883, NULL, wifiClient);
String _place;
String recivedData;
String json;
String jsonSave;
void heartBeatPrint(void)
  static int num = 1;
  if (WiFi.status() == WL_CONNECTED)
    dbSerialPrint("H");        // H means connected to WiFi
    dbSerialPrint("F");        // F means not connected to WiFi
  if (num == 80)
    dbSerialPrintln();
    num = 1;
  else if (num++ % 10 == 0)
    dbSerialPrint(" ");
void check_status() {
  // is configuration portal requested?
  if (firstConnection)
    dbSerialPrintln("\nConfiguration portal requested.");
    digitalWrite(PIN_LED, HIGH); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
    //Local intialization. Once its business is done, there is no need to keep it around
    ESP_WiFiManager ESP_wifiManager;
    ESP_wifiManager.setSaveConfigCallback(saveConfigCallback);
    //Check if there is stored WiFi router/password credentials.
    //If not found, device will remain in configuration mode until switched off via webserver.
    dbSerialPrint("Opening configuration portal. ");
    Router_SSID = ESP_wifiManager.WiFi_SSID();
    if (Router_SSID != "")
      ESP_wifiManager.setConfigPortalTimeout(120); //If no access point name has been previously entered disable timeout.
      dbSerialPrintln("Got stored Credentials. Timeout 120s");
      dbSerialPrintln("No stored Credentials. No timeout");
    ESP_WMParameter custom_place("Place", "Place", placeWifi, 60);
    ESP_wifiManager.addParameter(&custom_place);
    ESP_wifiManager.setMinimumSignalQuality(-1);
    // Set static IP, Gateway, Subnetmask, DNS1 and DNS2. New in v1.0.5
    ESP_wifiManager.setSTAStaticIPConfig(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
    //it starts an access point
    //and goes into a blocking loop awaiting configuration
    if (!ESP_wifiManager.startConfigPortal((const char *) ssid.c_str(), password))
      dbSerialPrintln("Not connected to WiFi but continuing anyway.");
      //if you get here you have connected to the WiFi
      dbSerialPrintln("connected...yeey :)");
      dbSerialPrint("Local IP: ");
      dbSerialPrintln(WiFi.localIP());
    strcpy(placeWifi, custom_place.getValue());
    digitalWrite(PIN_LED, LOW); // Turn led off as we are not in configuration mode.
    dbSerialPrintln("PLACE");
    dbSerialPrintln((const char*)placeWifi);
    _place = String(placeWifi);
    dbSerialPrintln("IN STRING: ");
    dbSerialPrintln(_place);
    recordPlace(10, _place);
  static ulong checkstatus_timeout = 0;
#define HEARTBEAT_INTERVAL    10000L
  // Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
  if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
    heartBeatPrint();
    checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
void saveConfigCallback () {
  dbSerialPrintln("Should save config");
  shouldSaveConfig = true;
void callback(char* topic, unsigned char* message, unsigned int length) {
  dbSerialPrint("Topic: ");
  dbSerialPrint(topic);
  dbSerialPrint(". Message: ");
  String messageTemp;
  messageTemp = "";
  json = "";
  for (int i = 0; i < length; i++) {
    dbSerialPrint((char)message[i]);
    messageTemp += (char)message[i];
  json = messageTemp;
  recordFile(json);
  dbSerialPrintln("Json save in SPIFFS");
  upSpiffs();
  EEPROM.begin(512);
  nexInit();
  btnInit.attachPush(startPage2, &btnInit);
  btnBack.attachPush(backPage1, &btnBack);
  SPIFFS.begin();
  if (!SPIFFS.exists("/infotest.json")) {
    dbSerialPrintln("file error");
    dbSerialPrintln("file ok");
    upSpiffs();
    deserializeJson(docSpiffs, jsonSave);
  recivedData = readPlace(10);
  dbSerialPrintln("Place in EEPROM:");
  dbSerialPrintln(recivedData);
  dbSerialPrintln("Connecting  wifi...");
  connectWifi();
  dbSerialPrintln("Connecting mqtt...");
  connectMqtt();
  client.setCallback(callback);
  client.setBufferSize(5044);
  dbSerialPrintln("End setup()");
  check_status();
  if (!client.connected()) {
    connectMqtt();
  client.loop();
  delay(100);
  nexLoop(nex_listen_list);
  switch (numberOfPage)
    case 0:
      if ((WiFi.status() == WL_CONNECTED) && (client.connected())) {
        dbSerialPrintln("Connect");
    case 1:
      if (timeMax.ding()) {
        numberOfPage = 0;
        pageInit.show();
      dbSerialPrintln("Open second page");
void recordPlace(char poss, String nome1)
  int _size = nome1.length();
  for (int i = 0; i < _size; i++)
    EEPROM.write(poss + i, nome1[i]);
  EEPROM.write(poss + _size, '\0'); //Add termination null character for String Data
  EEPROM.commit();
void recordFile(String rec)
  //Gravação do SPIFFS
  File f = SPIFFS.open("/infotest.json", "w");
  f.print(rec);
  f.close();
void upSpiffs()
  jsonSave = "";
  File f = SPIFFS.open("/infotest.json.json", "r");
  if (!f) {
    dbSerialPrintln("Error file (upSpiffs)");
    while (f.available()) {
      jsonSave = f.readStringUntil('\n');
    f.close();
    dbSerialPrintln("json spiffs save");
    dbSerialPrintln(jsonSave);
String readPlace(char ad)
  int i;
  char da[100]; //Max 100 Bytes
  int len = 0;
  unsigned char k;
  k = EEPROM.read(ad);
  while (k != '\0' && len < 500) //Read until null character
    k = EEPROM.read(ad + len);
    da[len] = k;
    len++;
  da[len] = '\0';
  return String(da);
void connectWifi() {
  dbSerialPrintln("\nStarting ConfigOnSwitch on " + String(ARDUINO_BOARD));
  unsigned long startedAt = millis();
  // Use this to default DHCP hostname to ESP8266-XXXXXX or ESP32-XXXXXX
  //ESP_WiFiManager ESP_wifiManager;
  // Use this to personalize DHCP hostname (RFC952 conformed)
  ESP_WiFiManager ESP_wifiManager("ConfigOnSwitch");
  ESP_wifiManager.setDebugOutput(true);
  // Use only to erase stored WiFi Credentials
  //resetSettings();
  //ESP_wifiManager.resetSettings();
  //set custom ip for portal
  //ESP_wifiManager.setAPStaticIPConfig(IPAddress(192, 168, 100, 1), IPAddress(192, 168, 100, 1), IPAddress(255, 255, 255, 0));
  // We can't use WiFi.SSID() in ESP32as it's only valid after connected.
  // SSID and Password stored in ESP32 wifi_ap_record_t and wifi_config_t are also cleared in reboot
  // Have to create a new function to store in EEPROM/SPIFFS for this purpose
  Router_Pass = ESP_wifiManager.WiFi_Pass();
  //Remove this line if you do not want to see WiFi password printed
  dbSerialPrintln("Stored: SSID = " + Router_SSID + ", Pass = " + Router_Pass);
  // SSID to uppercase
  ssid.toUpperCase();
  if (Router_SSID == "")
    dbSerialPrintln("Open Config Portal without Timeout: No stored Credentials.");
    digitalWrite(PIN_LED, HIGH); // Turn led on as we are in configuration mode.
      dbSerialPrintln("WiFi connected...yeey :)");
#define WIFI_CONNECT_TIMEOUT        2000L
#define WHILE_LOOP_DELAY            200L
#define WHILE_LOOP_STEPS            (WIFI_CONNECT_TIMEOUT / ( 3 * WHILE_LOOP_DELAY ))
  while ( (WiFi.status() != WL_CONNECTED) && (millis() - startedAt < WIFI_CONNECT_TIMEOUT ) )
    WiFi.mode(WIFI_STA);
    WiFi.persistent (true);
    // We start by connecting to a WiFi network
    dbSerialPrint("Connecting to ");
    dbSerialPrintln(Router_SSID);
    WiFi.config(stationIP, gatewayIP, netMask);
    //WiFi.config(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
    WiFi.begin(Router_SSID.c_str(), Router_Pass.c_str());
    int i = 0;
    while ((!WiFi.status() || WiFi.status() >= WL_DISCONNECTED) && i++ < WHILE_LOOP_STEPS)
      delay(WHILE_LOOP_DELAY);
  dbSerialPrint("After waiting ");
  dbSerialPrint((millis() - startedAt) / 1000);
  dbSerialPrint(" secs more in setup(), connection result is ");
    dbSerialPrint("connected. Local IP: ");
void connectMqtt() {
  int retries = 0;
  while ((!client.connected()) && (retries < 3)) {
    if (client.connect(usermqtt, "user", "p4assw0rd")) {
      dbSerialPrintln("mqtt conected!");
      client.subscribe("fitest01/test");
      dbSerialPrint("fail mqtt, erro =");
      dbSerialPrint(client.state());
      retries += 1;
void startPage2(void *ptr)
  pageSecond.show();
  numberOfPage = 1;
  timeMax.start();
void backPage1(void *ptr)
  numberOfPage = 0;
  pageInit.show();
PS: I save the information I receive via MQTT at SPIFFS, this information is a json. I also have a 30-second timer, which if I stay on the screen for more than 30 seconds without interaction, I return to the first one. This works well. The back to home screen button (btnBack) also works well.
Thank you!
Anyone?
