Delay with Working OLED Code with a Working Motor Code
Hi
I'm working on a project to produce an underwater scooter.
This includes two Maxon motors connected and controlled by force resistor sensors, this has been done successfully using an Elegoo Uno Rev 3 (Arduino Uno dupe) successfully.
In this I will also have a display screen (AZ Delivery OLED I2C Display Screen), this will show the value from a depth sensor (MS5400-CM) and the battery indicator.
Both of these set ups (Motor control and display screen) will run off the same Uno board.
I have two functioning codes for each:
Motor Control:
/* Simple example code for Force Sensitive Resistor (FSR) with Arduino. More info: https://www.makerguides.com */
// Define FSR pin:
#define fsrpin0 A0
int PWM_PIN0 = 6;
int PWM_PIN1 = 7;
int fsrreading0; //Variable to store FSR value
#define fsrpin1 A1
int fsrreading1; //Variable to store FSR value
//Define variable to store sensor readings:
  // Begin serial communication at a baud rate of 9600:
  pinMode(PWM_PIN0,OUTPUT);
  pinMode(PWM_PIN1,OUTPUT);
  // Read the FSR pin and store the output as fsrreading:
  fsrreading0 = analogRead(fsrpin0);
  if (fsrreading0 < 10) {
   analogWrite(PWM_PIN0, fsrreading0);
  } else if (fsrreading0 < 200) {
   } else if (fsrreading0 < 500) {
   } else if (fsrreading0 < 800) {
  delay(100); //Delay 500 ms.
    fsrreading1 = analogRead(fsrpin1);
  if (fsrreading1 < 10) {
   analogWrite(PWM_PIN1, fsrreading1);
  } else if (fsrreading1 < 200) {
   } else if (fsrreading1 < 500) {
   } else if (fsrreading1 < 800) {
   analogWrite(PWM_PIN1, fsrreading0);
Display Screen:
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, U8X8_PIN_NONE);
 void setup(void) {
   u8g2.begin();
  void loop(void) {
   u8g2.clearBuffer();					// clear the internal memory
   u8g2.setFont(u8g2_font_pxplusibmvga9_tf);  // choose a suitable font at https://github.com/olikraus/u8g2/wiki/fntlistall
   u8g2.drawStr(8,20,"Depth:");	// write something to the internal memory
   u8g2.drawStr(8,55 ,"insert");  // write something to the internal memory
   u8g2.sendBuffer();					// transfer internal memory to the display
   delay(3000);
   u8g2.drawStr(8,20,"Battery:"); // write something to the internal memory
   delay(3000);
However, when these have been merged together, it has a 4 second delay for the motor control. Previously this was instant! The display screen is also working as expected.
Merged Code:
// Define FSR pin:
#define fsrpin0 A0
int PWM_PIN0 = 6;
int PWM_PIN1 = 7;
#define fsrpin1 A1
// Include Wire Library for I2C
#include <Wire.h>
// Include Adafruit Graphics & OLED libraries
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Include Adafruit AM2320 Temp Humid Library
// Reset pin not used but needed for library
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
  u8g2.begin();
   delay(3000);
   delay(3000);
I was wondering if some could explain how I should be merging them to remove this (new) delay or if they can see a basic error that is making this incorrect.
Thank you !
Catherine
You have a delay(3000) at the end of loop. That was fine when your sketch only had to update the display every three seconds, but now it has to go.
Look at the blink without delay example in the IDE to see how to use millis for this purpose.
