Delay without stopping the Program to receive input
I just started a project to control an irrigation pump remotely using text messages. Arduino Uno and GSM shield.
It is not too hard to simply say "pumpon" in a text message and have it turn on the pump. Where I am having a problem is when I get more complicated. I would like to do 3 things at once. I would like to be able to send the pump a length of time to be on. Time frames being 2, 4, 6, 8, 10, or 12 hours. i.e. "pumpon12" While the pump is in its timing sequence I would also like to monitor a fault input and send a text message to my phone if a fault were to occur. I would also like to monitor an analog pressure input and and send myself a message if the pressure were to go out of a certain threshold.
If I simply put in a delay for 12 hours to hold the pump on for that time I am unable to monitor the fault or the pressure inputs. I want to learn how to do this but I just don't know where to begin looking. I looked under interrupts which seem sort of promising but I don't think I fully understand what they do or how to use them. Maybe a timer might have a chance here but I really just don't know what might the easiest route. Also with my current knowledge of using delays says to input 12 hours I need delay(43200000) I am not sure if that is even possible and I haven't been patient enough to find out.
Thank you in advance for you help,
You all are amazing!
Jake
Read the "Blink without delay" tutorial.
You need to do more than read it. You need to understand and embrace the philosophy that is espouses. That will allow you to let go of the delay() crutch.
