Hello friends, I'm going to ask about a classic: delay ()
I have a function that lights a led for a while (byte m), but I have it with delay () and I would like to remove it (because it gives me problems)
void execute (byte m) {
byte n;
digitalWrite (relay, HIGH);
for (n = 0; n <(m); n ++)
delay (1000);
digitalWrite (relay, LOW);
Anyone have a proposal ?? I have been searching the internet and propose millis (), but I am not clear how it works or how to include it in my function
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing without blocking. It may help with understanding the technique.
Forgive my inability, but I can not do it. I am in agreement that the Example is VERY well explained, but nothing, I do not get it (and I am aware that it should be really easy).
Some charitable soul to help me with the function (remember that it is not in the loop)
void execute (int m) {
byte n;
delay (1000);
(this would be the function to modify)
When it arrives at the function CurrentMillis = 11000 aprox, and I wanted the LED turn on with the value of int m (milliseconds)
You wait till the water boils and put the egg in.
You look on the clock and remember the start time that you put it in
You keep on looking on the clock
Once the required time (delay) has passed, you take the egg out
if water boils
execute 4 minutes
void execute(unsigned long delayTime)
if egg not yet in water
put egg in water
else if current time - start start >= delay time // keep on checking time
take egg out
do nothing
Translated to your situation
static unsigned long startTime = 0;
// if egg not yet in water
if (startTime == 0)
// put egg in water
digitalWrite(relay, HIGH);
// remember start time
startTime = millis();
// else if it's time to take it out
else if (millis() - startTime >= delayTime)
// take it out
digitalWrite(relay, LOW);
// reset start time (for the next egg)
startTime = 0;
Now it can also be useful to know when the boiling of the egg is finished; for that we can let the function return a status
switch on relay for given duration
returns true if the duration has passed, else false
note: none-blocking; call repeatedly
bool execute(unsigned long delayTime)
if (startTime == 0)
return false;
startTime = 0;
return true;
return false;
And in loop we can call it e.g. like this
if(execute(1000) == true)
Serial.println("execute finished");
// delay added to see led flash
delay() is like putting on the egg, and then sitting there watching the minute hand until it has moved the proper amount.
Using millis() is like putting on the egg, looking at the clock, calculating what time the egg will be done, and then periodically check the clock to see whether the "end time" has been reached.
The "periodically" is important - you must come back from some kind of loop to check the end-times. I'd guess that your problem - you have a subroutine buried far down in your logic, to turn on the relay for a particular time, and there is no way for THAT FUNCTION to do a non-delay based shut off of the relay, because it isn't even called periodically.
Instead, you have to implement a new function that IS called periodically to turn off the relay.
boolean relayActivated = false; // has the relay been turned on?
unsigned long relayOffTime; // when does the relay get turned off?
digitalWrite (relay, HIGH); // Turn on the relay
relayActivated = true; // Notice that it's been turned on
relayOffTime = millis() * (1000UL * m); // calculate when it needs to go off, and save that time.
// Complicated logic that eventually calls execute(), sometimes, perhaps.
checkRelayOff(); // Now check whether the relay needs turned off.
// More code, perhaps.
// function to check if relay needs to be turned off.
void checkRelayOff() {
if (relayActivated) { // Is the relay on?
if (millis() >= relayOffTime) { // Is it time (or past time) to turn it off?
digitalWrite(relay, LOW); // turn it off
(You'll want to notice that the above code doesn't handle the fact that millis() will wrap around after 50 days or so, in the interest of clarity. How to fix that is described elsewhere.)
(also notice that once you use this sort of non-delay() timing, you have to use it EVERYWHERE that is called from loop(); if you have any actual delay() calls, they'll interfere with the promptness of the millis() based checking.)
Hello!!!
I got it !! in the end I did it with the "timer.setTimeout", and I left it perfect.
I had to change my way of programming the instruction, since I indicated that the LED was on when I called the function, and now, what it does, is to turn off the led when the function calls, but the result is the same !!
by the way, I came back to try to solve the problem with millis (), since some believed that I had tried it a short time (since they only saw the time between post and post, and not the time I had spent fighting).
I solved it. Thanks to sterretje and westfw who taught me the way.
