Hello ![]()
I'm having trouble understanding how to program a delayed "double check" on a digital input. I want to sense a digital input change and then check it again 5s later to make sure it is a permanent change.
I have pasted the relevant code from my script below. The loop routine checks to see if a digital pin, DryerPin, has changed state. If it has, a timer is started (DryerCheckDelay, currently set to 5000ms).
After that time expires the code should check that the DryerPin is STILL in the new state - if so, it calls a routine SendData(StrToSend). The SendData routine works well. If DryerPin is not in the new state DryerInChange is reset to 0 and we start again.
The code in my loop routine doesn't work properly. It detects the change of state but doesn't wait the 5000ms; instead it reports the change immediately.
I am probably misunderstanding something. I would be grateful if someone could point out what. ![]()
#include <SPI.h>
#include <Ethernet.h>
// Set up pins
int DryerPin = 30; // Digital in for dryer on/off digital sensor
// Set up dryer sensor
int DryerState = 0; // dryer off initially
int OldDryerState = 0; // Previous dryer state
int DryerCheckDelay = 5000; // millis to wait between checks to see if dryer is still at new state
unsigned long ChangeMillis = 0;
unsigned long CurrentMillis = 0;
int DryerInChange = 0; // Is the dryer in a changed state?
char StrToSend[20];
void setup()Â {
pinMode(DryerPin, INPUT);Â Â Â Â Â // set pin to input
digitalWrite(DryerPin, HIGH);Â Â Â // turn on pullup resistors
DryerState = digitalRead(DryerPin);
    CurrentMillis = millis();
// Serial.println(DryerState);
if (DryerState != OldDryerState && DryerInChange == 0) { // Start timer before 2nd check
ChangeMillis = CurrentMillis;
        DryerInChange = 1;
   Â
    if(DryerInChange == 1 && CurrentMillis - ChangeMillis > DryerCheckDelay) {
     // If dryer state changing and we have waited long enough
     if (DryerState != OldDryerState) { // Still changed state - send the change of state now
        DryerInChange = 0;
        sprintf(StrToSend, "d=%d", DryerState);
SendData(StrToSend);
OldDryerState = DryerState;
      DryerInChange = 0; // Not permanent change, so stand down
void SendData (char *ToSend) {
// This bit works fine :-)
// Idea from http://arduino.cc/en/Tutorial/WebClient
if (client.connect()) {
Serial.println("Connected");
// Make a HTTP request:
client.print("GET /~maidhous/dev/input/in.php?");
client.print(ToSend);
Serial.println(ToSend);
client.print("&p=");
client.print(DataWritePassword); // Password
client.println(" HTTP/1.0");
client.println();
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
//Serial.println("Server responded");
//char c = client.read();
//Serial.print(c);
// if the server's disconnected, stop the client:
//if (!client.connected()) {
//Serial.println();
//Serial.println("Disconnecting.");
delay(30);
client.stop();
