Delayed Relay and Instant Relay for CNC support
Hey Guys!
I’m working on some more automation project for my CNC shop and got stumped on this code…that I thought would be really simple!
Background: Using ESP8266 to control two solidstate relays. One will be for an pneumatic solenoid. The part seems to work fine. The other (my problem area) is controlling a ball valve. I want to read a simple high/low level sensor, then turn on a ball valve. This ball valve needs to stay on until high level is reached and then stay on for a little bit longer (FillTime).
Right now, as soon as the FloatState goes HIGH, it closes the valve and does not delay. Also the first 10 seconds of power one is goes to the else statement…Any input to fix these issues and make my code more robust? I’m thinking it’s something simple, but I’ve been staring at this code for days…Thanks!
#include <ezButton.h>
ezButton Currentsen(4);   //D2
const int Airblast(9);    //SD2
const int Floatsen = 0;     //D3
const int Ballvalve = 10;    //SD3
int valvetime = 0;
int FloatsenState = 0;
int FillTime = 10000;
  Currentsen.setDebounceTime(50); // set debounce time to 50 milliseconds
  Serial.begin(9600); // See the connection status in Serial Monitor
  pinMode(Airblast, OUTPUT);
  pinMode(Ballvalve, OUTPUT);
  Currentsen.loop(); // MUST call the loop() functions first
  if (Currentsen.isPressed())
    Serial.println("Conveyor ON");
  digitalWrite(Airblast, HIGH);
  if (Currentsen.isReleased())
    Serial.println("Conveyor OFF");
  digitalWrite(Airblast, LOW);
  unsigned long CoolantTimer = 0;
  int FloatState = digitalRead(Floatsen);
  if ((FloatState == HIGH) && (millis() - CoolantTimer >= FillTime))
    Serial.println("COOLANT GOOD!");
    digitalWrite(Ballvalve, LOW);
  else {
    digitalWrite(Ballvalve, HIGH);
    Serial.println("ADDING EXTRA COOLANT");
  if (FloatState == LOW)
    CoolantTimer = millis();
    Serial.println("COOLANT LOW!");
    Serial.println("VALVE OPEN");
Okay…after some rearranging of the if/else statements, got it mostly working right. Now it’s just the start-up. It defaults to the else (Adding Extra Coolant) until it gets some time built up (the fill time). Eventually I will want the “fill time” to be a few minutes. Any idea on how to get the initial state happy if the level sensor is high? Thanks!
int valvetime = 0;
const long FillTime = 10000;
  unsigned long OffTimer = millis();
  if ((FloatState == HIGH) && ((OffTimer - CoolantTimer) >= FillTime))
  else if (FloatState == LOW)
    CoolantTimer = OffTimer;
  else {
@bwprecision
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
How is Floatsen wired? Why does it not have a pinMode() statement in setup()?
Hmm…that seemed to work without it, but added that in. Not sure how/why that worked either way. I usually leave it out in most of my scripts when doing basic relay/button stuff.
After hours/days of staring at this…I finally gave up on the millis() stuff. Not sure why I couldn’t make it happy. Went back to simple/basic math and this is what I came up with. Any suggestions for making it more robust or tips for next time? I plan on adding lots more automation to my machine shop. Thanks!
const long FillTime = 10000; //On time (milliseconds) after float goes HIGH
unsigned long CoolantTimer = FillTime; //Initialize as equal for startup state
  pinMode(Floatsen, INPUT_PULLUP);
  if ((FloatState == HIGH) && (CoolantTimer >= FillTime))
    CoolantTimer = 0;
  else {
    CoolantTimer = CoolantTimer + 1000;
This (from the code in Reply #4)
does the digitalWrite() regardless of the state of Currentsen. Which means that this
is effectively the same as
which is not much use.
Assuming the digitalWrite()s should be controlled by the IF tests the code should be like this - with {}
  if (Currentsen.isPressed()) {
...R
