Delaying process
Dear all,
I wanted to know how to delay a process without affecting main code.
#include <MsTimer2.h>
int Analog_Pin=5;
int newaverage;
float Output_Current;
#define RELAY1  7
#define MAX_TRIP_COUNT  5
float Current_Limit=0.6;
static int Trip_Count=0;
static int Tripped_Flag=1;
int Serial_Status=0;
void TakeReading()
  newaverage = analogRead(A5);
//  Serial.print("newaverage:");
  //Serial.println(newaverage);
  Output_Current = 0.0336666666667*newaverage - 17.17;
void Chk_Relay_Tripped()
  if(Output_Current>=Current_Limit)
    Trip_Count=Trip_Count+1;
    if((Trip_Count>=MAX_TRIP_COUNT) &&(Serial_Status==0))
      Trip_Count=0;
  MsTimer2::set(30000, Relay_Activate); // 500ms period
  MsTimer2::start();
     // Relay_Activate();
      if(Serial_Status==1)
        Serial.println("> MODE");
        Relay_Deactivate();
    Trip_Count=Trip_Count-1;
    if(Trip_Count<0)
      Trip_Count=0;
    if(Trip_Count<MAX_TRIP_COUNT && Serial_Status==1)
      Relay_Deactivate();
      Serial_Status=0;
void Relay_Activate()
   // MsTimer2::stop();
   for (unsigned long start = millis(); millis() - start < 10000;)
    digitalWrite(RELAY1,HIGH);
    Serial_Status=1;
    Serial_Status=1;
void  Relay_Deactivate()
  digitalWrite(RELAY1,LOW);
 // Serial_Status=0;
void Relay_Intialize()
  Serial.begin(9600); // set serial speed
  pinMode(RELAY1, OUTPUT); // set LED as output
  //digitalWrite(RELAY1, LOW); //turn off LED
  pinMode(Analog_Pin,INPUT);
  Relay_Intialize();
void loop(){
  TakeReading();
  Chk_Relay_Tripped();
  Serial.println(Output_Current);
   //while (Serial.available() == 0); // do nothing if nothing sent
  int val = Serial.read() - '0';
  if (val == 1) { // test for command 1 then turn on LED
    Serial.println("RELAY on");
    digitalWrite(RELAY1, LOW); // turn on LED
    Serial_Status=1;
  else if (val == 0) // test for command 0 then turn off LED
    Serial.println("RELAY OFF");
    digitalWrite(RELAY1, HIGH); // turn off LED
    Serial_Status=0;
In below code , In below function It will wait for 30S to execute once 30s elapsed other thing s will be printed. But i wanted to print even in 30s . What need to change in below code.
  for (unsigned long start = millis(); millis() - start <30000;)
    Serial_Status=1;
There is ONLY one process, so talk of a process separate from the main code is meaningless.
No, it doesn't. It TAKES 30 seconds to execute - mostly doing nothing.
Let us all intone the mantra
"Look at blink without delay, without delay. Ommmmm"
look to call the delayed function like this, untested:
turns on a relay after 30 seconds and back on after 5.
if (something) // start the timer
  startTime = millis(); // start time, a global unsigned long
relay_Activate(30000UL,5000UL);
where 30000UL is the time you want the delayed action to begin
void Relay_Activate(unsigned long delayTime, unsigned long duration)
  static boolean printed = false;
  if (millis() - startTime <= delayTime)
    // do nothing
  else if (millis() - startTime <= delayTime + duration)
    if (!printed)
      Serial_Status = 1;
      printed = true;
    Serial_Status = 0;
    printed = false;
  //never reset the startTime in the loop
Thanks for support . solved.
