delays break Timer1 and MsTimer2
I was trying this code, and with some help from the people at #arduino channel @ freenode I found that the delay function breaks the mstimer2, I tried also the timerone and the same error.
#include <MsTimer2.h>
// Switch on LED on pin 13 each second
long time = 200;
void flash() {
  digitalWrite(13, HIGH);
  digitalWrite(12, HIGH);
  delay(100);
  digitalWrite(13, LOW);
  digitalWrite(12, LOW);
  Serial.println("Flashing");// debuging purposes
void timesetup(int t) {
  MsTimer2::set(200, flash); // 500ms period
  MsTimer2::start();
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  timesetup(500);
 // timesetup(time);
  //long rcv = 200;
  //Serial.read(rcv)
  //if (rcv != time);
    //timesetup(rcv);
    //time = rcv;
please, give your thoughts, the delay is at the flash function.
the error is that the led lights up, but doesn’t blink, even once.
What does this do:
[UNTESTED CODE]
volatile boolean doBlink = false;
void flash() {
doBlink = true;
MsTimer2::start();
timesetup(500);
if(doBlink){
delay(100);
//Serial.println(“Flashing”);// debuging purposes
doBlink = false;
thank you for the idea, but I'm not seeing what is the difference in real, since the code is really far from what I wanted to do. I don't want to have delays at the main loop, and I already solved the problem using a counter triggered by the timer. Anyway the post was to show that the delay() was messing up with the mstimer2. so I lost more tha 2 hours to find that.... it is only a warning :)
If you got a solution, why not post? :)
BTW: the purpose was to make the ISR as short as possible.
here is the solution, and a video showing the result
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1240926680
