Hi there.
I am trying to make a function which deletes all the files on the SD card by the push of one button. The files on the card is created by a datalogger which creates logger00.csv files from 00 to 99.
This is how i think is should be made, by creating a for loop, which deletes the files one by one, but i can figure out how to program the rest?
best regards Bastian
here is my code. I hope you could help me.
SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
File myFile;
int deletePinSD = 5;
boolean deleteboolean = false;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(53, OUTPUT);
pinMode(deletePinSD, INPUT);
if (!SD.begin(53)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
if (digitalRead(deletePinSD)==LOW)
// delete the file:
if (digitalRead(deletePinSD)==HIGH)
deleteboolean = true;
if (deleteboolean==true)
Serial.println("Removing example.txt...");
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++)
SD.remove(filename);
if (SD.exists(filename)){
Serial.println("Could not delete all data");
Serial.println("All files deleted");
