Delete Custom Libs from Arduino Web Editor
Hi to you all! :slight_smile:
A while ago it was not possible to delete custom libs from the web editor. Is this feature already implemented? I ve been searching the forum and did not fin anything new.
Thank you :slight_smile:
Yes, it is now possible to delete custom libraries in the Arduino Web Editor:
  • Click on the "Libraries" tab on menu at the left side of the screen.
  • Click on the "Custom" tab.
  • Hover the mouse pointer over the library you want to delete.
  • Click the downward pointing triangle button that appears.
  • Click "Delete Library".
Thank you for your prompt answer.
I just tested under chrome and it is there, the option for delete. I was using the opera browser before, wich I believe is not 100% compatible with the Web Editor options.
Solved for me. Thanks again.
You're welcome. I'm glad if I was able to be of assistance.
I also use Arduino Web Editor with Chrome. I haven't ever tried it with Opera. I'm glad to hear it's working for you now. Enjoy!
Per
