delete string variable after executed
im trying to use serial monitor to control arduino. it only works on the first try. I noticed that the string variable in 'msg' was not deleted, i've tried to delete the string within the variable 'msg' using the function msg = ""; for it to be ready for the next command, but it doesnt seem to work.
//library(time.h & TimeAlarms.h) installed from: http://playground.arduino.cc/Code/Time
#include <Time.h>
#include <TimeAlarms.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
int Relay1 = 3;
int Relay2 = 4;
char state = 0;
int ledpin = 5;
String msg = "";
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
{ pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  pinMode(ledpin, OUTPUT);
  sensors.begin(); // IC Default 9 bit. If you have troubles consider upping it 12. Ups the delay giving the IC more time to process the temperature measurement
  setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
  // create the alarms
  Alarm.alarmRepeat(12,00,00, AC1on);
  Alarm.alarmRepeat(12,05,00, AC2off);
  Alarm.alarmRepeat(00,00,00, AC2on);
  Alarm.alarmRepeat(00,05,00, AC1off);
void  loop(){
if (Serial.available()>0){
    char pdata= Serial.read();
    msg += pdata;
 if (msg == "lights on"){
    digitalWrite(ledpin,HIGH);
  msg = "";}
 else if (msg == "Lights off"){
    digitalWrite(ledpin,LOW);
  msg = "";}
 else if (msg == "info"){
     sensors.requestTemperatures(); // Send the command to get temperatures
     Serial.print("current Temperature is: ");
     Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
     Serial.print("The current time is: ");
     Serial.print(hour());
     printDigits(minute());
     printDigits(second());
     Serial.print("Air conditioning status: ");
     msg="";
     Serial.println(msg);
{msg=="";}
// functions to be called when an alarm triggers:
void AC1on(){
  Serial.println("AC1 on");    //print "AC1 on" on serial monitor
  digitalWrite(Relay1, LOW);  //trigger AC1 relay
void AC2off(){
  Serial.println("AC2 off");    //print "AC1 on" on serial monitor
  digitalWrite(Relay2, LOW);  //trigger AC1 relay
void AC2on(){
  Serial.println("AC2 on");    //print "AC1 on" on serial monitor
  digitalWrite(Relay2, HIGH);  //trigger AC1 relay
void AC1off(){
  Serial.println("AC1 off");     //print "AC2 on" on serial monitor
  digitalWrite(Relay1, HIGH);   //trigger AC2 relay on
void printDigits(int digits)
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
when i tried to run it and type "info" in the serial monitor, this is the output
i
in
inf
current Temperature is: 27.50
The current time is: 8:29:06
which is fine but when im going to type it over, im getting this instead,
i
in
inf
info
info
msg=="";
This seems to be catching out a lot of people today. == is equality, you want assignment, =.
Although even with that, not sure it'll work, you read one character at a time, and if it doesnt match, you clear it.
Also I recommend switching to strings (char arrays) as opposed to Strings (the class).
well that
{msg=="";}
shouldnt be there actually, if i correct t. ill get no command at all as it will just delete every single character.
No point keeping it there if its incorrect, and to correct it would break the way the program works :wink:
Any more things you left in that need taking out before I look through?
nevermind, i just solved it.. i added while loop in it.. thanks for responding anyway.. :wink:
