deleted
delete
The actual error message contains a lot more information than that....
Regards,
Ray L.
there are things in your code that don't make sense like:
bool done which is then re-declared as float!!!!!
anyway 'radio.read' is a 'void' function ie it does not return anything... hence your error.
if you change the initial 'if' statement to so something like this, it compiles:
  if (radio.available())
    radio.read(&senderId, 1);
The function does not return a value.
You can’t assign the value it doesn’t return to a variable.
If you search through the RF24.h file you are including, you will see that .read is a void function, it does not return a value.
void RF24::read( void* buf, uint8_t len )
  // Fetch the payload
  read_payload( buf, len );
  //Clear the two possible interrupt flags with one command
  write_register(NRF_STATUS,_BV(RX_DR) | _BV(MAX_RT) | _BV(TX_DS) );
It's the classical case of an old-library-sample-code used with the newer and better library.
