how do we create and delete objects in arduino uno explicitly?
i am using multiple IR sensors and reading them on the same pin (10) of the arduino Uno R3 board.
when im running the program, im facing memory leakage.
so i thought of creating and deleting the objects of the IR classes every time the receive function is called.
void receive() {
str = "receiving for sensor at pin " + String(i);
// prints the i[sup]th[/sup] sensor's readings.
// i is declared as global variable and is used in for-loop in the "loop()" part of the program
Serial.println(str);
IRrecv irrecv(10);
decode_results results ;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results))
Serial.println(" " + String(results.value));
irrecv.resume(); // Receive the next value
results.value = 0;
free(irrecv); //delete the receiver object
free(results); //delete the results object
when i compile, i get an error like this:
error: cannot convert 'decode_results' to 'void*' for argument '1' to 'void free(void*)'
I don't know that you need to free them. The way you are accessing them makes it look like they are not pointers but real objects. So they'll be destroyed for you when they go out of scope. Can you show the whole code?
Delta_G:
I don’t know that you need to free them. The way you are accessing them makes it look like they are not pointers but real objects. So they’ll be destroyed for you when they go out of scope. Can you show the whole code?
u sure about that? objects memory getting released once they go out of scope?
the code
#include <boarddefs.h>
#include <IRremote.h>
#include <IRremoteInt.h>
String str = "";
void activate();
void activate(int pin) {
IRrecv irrecv(10);
digitalWrite(pin, HIGH);
//Serial.print(" ");
Serial.println(results.value);
str = "ended recieving for sensor at pin " + String(pin) ;
//results.value = 0;
// Serial.println(str);
digitalWrite(pin, LOW);
pinMode(2, OUTPUT); //power supply to1 sensor
pinMode(3, OUTPUT); //power supply to 2nd sensor
pinMode(10, INPUT); //common input pin for all the recievers
for (i = 2; i < 4; i++) {
str = "ACTIVE PIN " + String(i);
activate(i);
my plan is to supply power to the sensors using the for-loop in the loop() function, sending the command to activate(int pin) method which sets appropriate pin HIGH…
it is working though…
when the pin 3 is activated, but there is no sensor at pin 3, the serial monitor displays results for pin 3…
any idea how to fix it???
i was earlier using the all variables as global, now i moved to parameterised methods and still the same happens…
iwbatz:
I am absolutely positive about it. Since you never use new or malloc in your code you have no use for free.
iwbatz:
when the pin 3 is activated, but there is no sensor at pin 3, the serial monitor displays results for pin 3...
It's not clear what you mean here. What sensors? You seem to assume that we know something about your project that you haven't shown yet. Namely what is connected and how. But I have to ask, how will Arduino know whether or not something is connected to pin 3?
