dellays
can some one help me im trying to make a stepper, servo, and a dc motor run simultaneously but im having trouble with the code because of delays wont allow me to run them at the same time. i have the stepper motor on pins 8,9,10, and 11. then the servo is on pin 6 and lastly the dc motor is on pin 5. I just need the dc motor to be able to turn continuously, the servo to swivel dependent on a given integer and the stepper to rotate clockwise and counter clockwise for a given amount of time.
here is the code for the stepper motor
int motorPin1 = 8;
int motorPin2 = 9;
int motorPin3 = 10;
int motorPin4 = 11;
int delayTime = 10;
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
//onephase();
 //onephaseup();
 // twophase();
 //one_twophasedown();
 one_twophaseup();
void onephase(){
  digitalWrite(motorPin1, HIGH);
  digitalWrite(motorPin2, LOW);
  digitalWrite(motorPin3, LOW);
  digitalWrite(motorPin4, LOW);
  delay(delayTime);
  digitalWrite(motorPin1, LOW);
  digitalWrite(motorPin2, HIGH);
  delay(delayTime);
  digitalWrite(motorPin3, HIGH);
  delay(delayTime);
  digitalWrite(motorPin4, HIGH);
  delay(delayTime);
void onephaseup(){
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
void twophase(){
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
  delay(delayTime);
void one_twophasedown(){
 //1
  delay(delayTime);
  //2
  delay(delayTime);
  //3
  delay(delayTime);
  //4
  delay(delayTime);
  //5
  delay(delayTime);
  //6
  //7
  delay(delayTime);
  delay(delayTime);
  //8
  delay(delayTime);
void one_twophaseup(){
 //8
  delay(delayTime);
  //7
  delay(delayTime);
  delay(delayTime);
  //6
  delay(delayTime);
  //5
  delay(delayTime);
  //4
    delay(delayTime);
  //3
    delay(delayTime);
  //2
  delay(delayTime);
   //1
  delay(delayTime);
and here is the code for the servo
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int time = 15;
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  delay(60000);
  for(pos = 90; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(time);                      // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
  for(pos = 0; pos < 90; pos += 1)  // goes from 0 degrees to 180 degrees
and then the motor is just connected to pin 5 and needs to be turned on for a givin amount of time while the other motors are running.
To which the obvious answer is - get rid of the delays.
Whilst you're getting rid of the delays, add some code tags to your first post.
So, get rid of them. The blink without delay example shows you how.
You'll need to implement a state machine. On any pass through loop, you are in some state - figure out what to do, if its time to do something, based on the state you are in.
thats what im having issues with. i cant figure out how to remove the delays. and yes i have looked at the arduino tutorial.
This demo several things at a time should help.
Also learn how to use arrays to save yourself an awful lot of typing with the associated risk of errors.
…R
thanks this helps a bunch.
This is another take on the same topic
http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html
Still waiting for you to modify that original post.
