Hi to all.
After few weeks i started similar topic but i guess it's better to start a new one because i have some new information and the concept has changed. When someone will read this, please be so kind and try to answer each question. Am writing down everything so i can document it for possible future use. In end effect, whole community will gain from it.
SPECS and questions:
1.) Dimension of longer arm will be cca 1 meter and shorter one ( the one attached to motor ) will have length of cca. 30 cm. Everything will be made from aluminum. Weight of whole arm will be between 0.5 -1KG. When i add gearbox to the motor, what kind of power for this motor, should i take into consideration ? The reason am asking this is because i want to use RADDS but i can not find any relevant info on motor power consumption. Can i use some 50W stepper motor for such setup ?.
2.) From my point of view, i should need some stronger motor for one additional thing...
Number of the objects that will be picked from the conveyor track will be between 50 - 60 per minute.
This can not be done with some small stepper motor ( because of the gearbox part ).
3.) Image recognition
First part of the project is to detect colored items and sort them out. For this am planning to use arduino color sensor or maybe some camera. What would be better option ?
4.) I can use raspberry and camera as image detection and processing part. But,i dont know how fast will this this RSP --> arduino part work...Basically, i want to avoid using RSP for anything else accept for image processing and sending signal to arduino...
Best regards !
