Hello,
I'm trying yo upload the following code into an Arduino Nano:
#include <Wire.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
// initialize the LCD
lcd.begin();
// Turn on the blacklight and print a message.
lcd.backlight();
lcd.print("Hello, world!----");
// Do nothing here...
I have two different files in different folders and one compiles with no problem, but the other launches the following error:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Nano, ATmega328P"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/angel/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114 -warnings=all -build-cache /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_cache_803058 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Volumes/Data/mimaServer/02.usMIMA/ACD/Projects/P20-004#STRT-IMPR#_Stress_test_ASTB_V02_02/Design/SOL-OP-01/code-snippets/16x2_LCD/16x2_LCD-I2C/16x2_LCD-I2C.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/angel/Documents/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10813 -build-path /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114 -warnings=all -build-cache /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_cache_803058 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /Volumes/Data/mimaServer/02.usMIMA/ACD/Projects/P20-004#STRT-IMPR#_Stress_test_ASTB_V02_02/Design/SOL-OP-01/code-snippets/16x2_LCD/16x2_LCD-I2C/16x2_LCD-I2C.ino
Using board 'nano' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for LiquidCrystal_I2C.h: [LiquidCrystal_I2C]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [LiquidCrystal_I2C]
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src -I/Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C-.cpp
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src -I/Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.cpp
Using cached library dependencies for file: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/utility/twi.c
Using cached library dependencies for file: /Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.cpp
Generating function prototypes...
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src -I/Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp -o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src -I/Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp -o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp.o
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/eightanaloginputs -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src -I/Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C.cpp -o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C.cpp.o
Using previously compiled file: /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C-.cpp.o
/Volumes/Data/mimaServer/02.usMIMA/ACD/Projects/P20-004#STRT-IMPR#_Stress_test_ASTB_V02_02/Design/SOL-OP-01/code-snippets/16x2_LCD/16x2_LCD-I2C/16x2_LCD-I2C.ino:48:1: warning: "/" within comment [-Wcomment]
/Compiling libraries...
Compiling library "Wire"
Using previously compiled file: /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/Wire/Wire.cpp.o
Using previously compiled file: /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/Wire/utility/twi.c.o
Compiling library "LiquidCrystal_I2C"
Using previously compiled file: /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.cpp.o
Compiling core...
Using precompiled core: /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_cache_803058/core/core_arduino_avr_nano_cpu_atmega328_51f02b7210b938436b779d1c032618e1.a
Linking everything together...
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/16x2_LCD-I2C.ino.elf /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/16x2_LCD-I2C.ino.cpp.o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C-.cpp.o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C.cpp.o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/Wire/Wire.cpp.o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/Wire/utility/twi.c.o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.cpp.o /var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/../arduino_cache_803058/core/core_arduino_avr_nano_cpu_atmega328_51f02b7210b938436b779d1c032618e1.a -L/var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114 -lm
/var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C.cpp.o (symbol from plugin): In functionLiquidCrystal_I2C::LiquidCrystal_I2C(unsigned char, unsigned char, unsigned char, unsigned char)': (.text+0x0): multiple definition of
/var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/sketch/LiquidCrystal_I2C-.cpp.o (symbol from plugin):(.text+0x0): first defined here
LiquidCrystal_I2C::getBacklight()'
LiquidCrystal_I2C::expanderWrite(unsigned char)'
LiquidCrystal_I2C::noBacklight()'
LiquidCrystal_I2C::backlight()'
LiquidCrystal_I2C::pulseEnable(unsigned char)'
LiquidCrystal_I2C::write4bits(unsigned char)'
LiquidCrystal_I2C::send(unsigned char, unsigned char)'
LiquidCrystal_I2C::clear()'
LiquidCrystal_I2C::home()'
LiquidCrystal_I2C::setCursor(unsigned char, unsigned char)'
LiquidCrystal_I2C::noDisplay()'
LiquidCrystal_I2C::display()'
LiquidCrystal_I2C::noCursor()'
LiquidCrystal_I2C::cursor()'
LiquidCrystal_I2C::noBlink()'
LiquidCrystal_I2C::blink()'
LiquidCrystal_I2C::scrollDisplayLeft()'
LiquidCrystal_I2C::scrollDisplayRight()'
LiquidCrystal_I2C::leftToRight()'
LiquidCrystal_I2C::rightToLeft()'
LiquidCrystal_I2C::autoscroll()'
LiquidCrystal_I2C::noAutoscroll()'
LiquidCrystal_I2C::createChar(unsigned char, unsigned char*)'
LiquidCrystal_I2C::begin()'
LiquidCrystal_I2C::load_custom_character(unsigned char, unsigned char*)'
LiquidCrystal_I2C::setBacklight(unsigned char)'
LiquidCrystal_I2C::printstr(char const*)'
/var/folders/_g/4y6c5m2s4wl_ylj84jb37dy40000gn/T/arduino_build_521114/libraries/LiquidCrystal_I2C/LiquidCrystal_I2C.cpp.o (symbol from plugin): In functionLiquidCrystal_I2C::LiquidCrystal_I2C(unsigned char, unsigned char, unsigned char, unsigned char)': (.text+0x0): multiple definition of
collect2: error: ld returned 1 exit status
Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire
Using library LiquidCrystal_I2C in folder: /Users/angel/Documents/Arduino/libraries/LiquidCrystal_I2C (legacy)
exit status 1
Error compiling for board Arduino Nano.
It seems that each file uses different libraries taken from different places, but I cannot understand the criteria or identify where is the difference.
