DES with Padding PKCS7
Hi,, Iam adam.
I am still a newbie in security arduino . I have an example of DES security code with a maximum of 8 characters plaintext input string.
#include <DES.h>
DES des;
while (!Serial);
desTest();
delay(2000);
void desTest()
int n;
byte out[16];
byte in[] = ("#N1X5Y6!");
des.calc_size_n_pad(sizeof(in));
byte in_p[des.get_size()];
des.padPlaintext(in,in_p);
byte cyphertext[des.get_size()];
byte key[] = ("TELKOM12");
Serial.println("========= DES test ==========");
Serial.println("Start");
Serial.print ("Keyword = ");
for (int j=0;j<8;j++){
if (key[j]<0x10) Serial.print("0");
Serial.print(key[j],HEX);Serial.print(" ");
Serial.print ("Plaintext = ");
if (in[j]<0x10) Serial.print("0");
Serial.print(in[j],HEX);Serial.print(" ");
//encrypt
Serial.print("Encrypt...");
unsigned long time = micros();
des.encrypt(out, in, key);
time = micros() - time;
Serial.print("done. (");
Serial.print(time);
Serial.println(" micros)");
printArray(out);
//decrypt
for (int i = 0; i < 8; i++)
in = out*;*
* Serial.print("Decrypt...");*
* time = micros();*
* des.decrypt(out, in, key);*
* time = micros() - time;*
* Serial.print("done. (");*
* Serial.print(time);*
* Serial.println(" micros)");*
* printArray(out);*
void printArray(byte output[])
* for (int i = 0; i < 8; i++)*
_ if (output < 0x10)
Serial.print("0");
Serial.print(output, HEX);
Serial.print(" ");
I want to try to add padding to the size of the plaintext by using PKCS7. can anyone help me ?
I say thank you very much._
Looks like your code uses the DES library to pad the plaintext. Did you want to change the DES library so it would use PKCS#7 padding or did you want to pad your plain text with PKCS#7 so the DES library would have no padding to do?
I say thank you for your response. if possible to use PKCS7 on the main code is not in the library , can you help me ?
basically I just wanted to add the amount of plaintext . if I use the code above , for example :
in byte [ ] = (" # N1X5.78678975Y6.967678897 ! ") ;
then encrypted only the first 8 characters . and the rest of the other characters on ignore.
can you help me sir? thank you very much
   //decrypt
   for (int i = 0; i < 8; i++) {
       in[i] = out[i];
This part only copies 8 bytes from the encrypted array (out) so it can be decrypted.
   printArray(out);The "printArray()" function will only display the first 8 bytes of the array
Try using "des.get_size()" instead of "8" in the copy loop and in printArray().
