Design Question about detecting connections between devices
I have some design questions involving what will be an intermittent direct serial connection between an Arduino Mega 2560 and Wemos D1 Mini. They will not always be connected, but when they are connected then data passed via the serial connection.
Serial3 on the Mega. SoftwareSerial on the Wemos. Using a logic level convertor between Mega and Wemos and all grounds are common.
I have questions about is the status/behavior of the serial ports when they are NOT connected.
Question #1:
What happens when I run Serial.begin(57600) in setup() on either device while not connected? Will the ports get initialized even though disconnected and begin working once they are connected?
Question #2:
How to detect when they are connected?
Method A:
Use a ping style test serially sending the ping from one (or both) devices to the other one. When a ping response appears then I know they are connected.
Method B:
Detect electrically when the two are connected using a 3rd pin or perhaps even detecting the serial pins are connected somehow.
My preference would be some implementation of Method B because using the ping test seems a bit brute force to me, plus I don't know if there might be some problems with writing to serial ports for hours on end that aren't connected to anything.
What I have tried:
I tried using a 3rd pin to allow the Wemos to know when its connected (see snippet below). When Mega-pin8 is connected to Wemos-pinD4 then D4 is brought LOW. But when the 3rd pin is connected, the Wemos Tx no longer is detected on the Mega. It somehow screws up just the Tx on the Wemos. I am totally in the dark as to why that happens.
Wemos:
   void setup(){
   pinMode(D4, INPUT_PULLUP);
   if (digitalRead(D4) == LOW)  isConnected = true;
   else isConnected = false;
Mega:
void setup(){
   pinMode(8, OUTPUT);
   digitalWrite(8,LOW);
  1. Yes.
  2. Please be more specific about the connection and what it means to be "disconnected". Post a schematic diagram and identify the logic level converter.
Polling.
I'm sure you have some idea what that means to you. Polling the serial port? Polling the 3rd connected pin? Too vague to be of any meaningful help.
The serial port. You shouldn't complain about vagueness, considering that your post doesn't meet the standards of the forum introductory guide:
You haven't posted either a wiring diagram, or any complete sketch.
Polling is what you called, "Method A" in your first post... but you called it "pinging".
  1. Yes. The serial port doesn't know what if anything is connected to it, it doesn't care.
  2. Method A seems best. An electrical test could be devised but why bother with the extra circuitry when method A will work perfectly well?
    There is no problem writing to an unconnected serial port until the end of time, it shovels the data out and doesn't care whether it goes anywhere or not.
