harddrive123:
Nothing about this is really proprietary, its mostly derived parts of other circuits and recommended configurations from spec sheets all thrown together on one sheet. Aside from the h-bridge which in the end was also a modification on a different design I found.
If anything was proprietary, it would be in the routing which I'm not sharing.
Eagle file formats are binary and proprietry, not open-source. At anypoint
CadsoftUSA could decide to start charging for all versions of Eagle, they own the format.
They could (realistically) be bought out and closed down by a competitor...
Courtesy wikipedia:
Portable Network Graphics (PNG, pronounced "ping"), is a raster graphics file format that supports lossless data compression. PNG was created as an improved, non-patented replacement for Graphics Interchange Format (GIF), and is the most used lossless image compression format on the Internet.
PNG is also an international standard. It will be supported decades/centuries into the future.
....anyway.... back to the plot.
I see n-channel / p-channel bridge, presumably the PWM input is to the low-side
switches via the FAN3122 drivers (which are overkill, 100mA drivers would suffice
for those small Si4564's - still give 100ns switching).
The top-side p-channel circuit isn't engineered for PWM, those 10k pullups are woefully
slow, but if just used for direction and braking it doesn't really matter (I personally
would make them 1k anyway).
The layout is important too, low inductance paths to decoupling. Adding more decoupling
on the power rails would be good, 10uF ceramic is a start, but more electrolytic
bulk decoupling can reduce the noise on the rail - large voltage spikes on the rail could
overload the Vgs rating on the MOSFETs, note. Some people add TVS diodes to the
rail to help here.
How are you sensing current? Or is the supply or load current limited enough to prevent
blowing the MOSFETs? Overcurrent events when using powerful battery supply can
explode MOSFETs - for instance a big motor pulling double-stall current when reversed
at full power would be a worst-case situation to consider (try to prevent this ever happening)
You bridge is
