So basically what I'm working on is a robot with 2 high power wiper motors for the wheels, a low power motor for the ball kicking, a few zigbee's and wireless shields, arduino's and whatnot.
This is the modified joystick I have: http://tagisangrobotics.ph/dlds/Modified%20Joystick.pdf And here is the stuff I have besides the motors: http://tagisangrobotics.ph/dlds/Basic%20Remote%20Controller%20System.pdf Motor driver connection: http://tagisangrobotics.ph/dlds/Basic%20Motor%20Driver%20Connection%20V1.pdf http://tagisangrobotics.ph/dlds/Basic%20Motor%20Driver%20Connection%20V2.pdf
We've written down the X and Y coordinates of front,back,left,right,upper left, upper right, lower left and lower right movements using the serial read feature on the arduino software. (where the robot will move depending on how we move the joystick)
Instead of the traditional 1 motor will go reverse while the other forward to make a turn, One motor will have to go at full speed and the other will have to go slower in order to turn.
Here are the tasks I need to accomplish, i dont really know how to go about it:
Motor Movement: --> the function should accept 6 parameters, 3 for each motor. --> the 1st parameter is for direction: FORWARD or BACKWARD. --> the 2nd parameter is for time it is on: ONTIME --> the 3rd parameter is for the speed setting: FAST or MEDIUM or SLOW. the other three is for the other motor. so the function may look like this.
void motorControl(dirMotor1, timeMotor1, speedMotor1,dirMotor2, timeMotor2, speedMotor2) {
// do the processing here.
And here is my other task: data for calling the function motorControl(). --> preprocess the raw data from serial to extract and compute the following: 1. direction of the motor based on joystick data 2. speed of the motor based on the button of the joystick 3. compute the ontime of the motor depending on the XY data of joystick.
i was told i can test my work can by just typing on the serial monitor the expected raw data from joystick and printf the dirMotor1, timeMotor1, speedMotor1,dirMotor2, timeMotor2, speedMotor2 on the serial monitor.
Your help and input is highly appreciated and is needed ASAP. Thanks.
