Designing a test rig
Hello all
A friend of mine has a PCB he uses 'out in the field' for controlling contactors etc
It runs on a 64 pin PIC IC I believe and has multiple analogue and digital inputs and outputs.
He has asked if I can come up with some way of testing these PCBs.
By this, he means for EMF noise, RF interference etc.
I can easily test the power rails and switching with an oscilloscope. Its the RF noise and EMF I am wondering about.
I asked him how he originally tested them and he said they basically set a noisy 230v contactor up and switched it on and off for a length of time, right next to the PCB.
That doesn't seem very conclusive!
Any ideas? I was thinking maybe a spark generator on a pulsed timer.
I will go a Googling...
  • I’ve used an old crapy electrical drill that exhibits contact arcing, not very scientific.
    :woozy_face:
  • An old Model T coil.
That seems VERY conclusive, especially if a length of insulated wire was connected to ONE contact so it becomes a radiating antenna for the spark RF energy.
Remember to drive it at half speed, so you get little bit extra noise from triac.
You need specialised equipment to perform EMC compatibility tests.
If the board passes or fails the crude spark test , what conclusions can you draw ? Was it an unreasonable test ? Was the board susceptible ?
You need a faraday cage to check for emissions .
And ….
There no point in testing the boards , when fitted into an enclosure with other parts , the results can be very different .
Testing needs to be to recognised standards to be meaningful .
Tell him you can’t do it
