designing and testing
hi,
this is polisetty,i designed old version serial arduino(ATMega8) hardware board as per you schematic,but it's not working.My main confusion is which version arduino software is used and pc configaration also ,how to installed and how 2 use????. i used serial type with MAX232.please give support to me.
Do you have a bootloader in your AVR chip? You need one.
Check the board is working as a chip with just the boot loader in will flash the LED on Pin13, if you don't have a LED here just look at the pin on an oscilloscope.
I would use the latest.
If you are using the built in COM ports then nothing to configure.
So what messages do you get when you try?
