I think i almost have this code working however, the fatetocolour unction requires and int, byte, byte, int
and when i call it i and calling a string that holds the name of the correct corresponding byte variable however when i try to compile it says i am calling it with int, string, string, int :S
* CheerLights.pde
//RGB LED pins
int ledAnalogOne[] = {3, 5, 6}; //the three pins of the first analog LED 3 = redPin, 5 = greenPin, 6 = bluePin
//These pins must be PWM
int ledAnalogTwo[] = {9, 10, 11}; //the three pins of the second analog LED 9 = redPin, 10 = greenPin, 11 = bluePin
const byte ORANGE[] = {83, 4, 0};
const byte YELLOW[] = {255, 255, 0};
const byte GREEN[] = {0, 255, 0};
const byte BLUE[] = {0, 0, 255};
const byte INDIGO[] = {4, 0, 19};
const byte VIOLET[] = {23, 0, 22};
const byte CYAN[] = {0, 255, 255};
const byte MAGENTA[] = {255, 0, 255};
const byte WHITE[] = {255, 255, 255};
const byte BLACK[] = {0, 0, 0};
const byte PINK[] = {158, 4, 79};
String LastColour;
String CurrentColour;
// sb = HughesyShiftBrite(10,11,12,13);
//sb.sendColour(0,0,0);
for(int i = 0; i < 3; i++){
pinMode(ledAnalogOne[i], OUTPUT);
//Set the three LED pins as outputs
pinMode(ledAnalogTwo[i], OUTPUT);
setColor(ledAnalogOne, BLACK);
//Turn off led 1
setColor(ledAnalogTwo, BLACK);
//Turn off led 2
int input = Serial.read();
switch (input) {
case 48:
CurrentColour = "PINK";
fadeToColor(ledAnalogOne, LastColour, CurrentColour, 10);
//sb.sendColour(255,0,0); // red 0
case 49:
CurrentColour = "GREEN";
//sb.sendColour(0,1000,0); // green 1
case 50:
CurrentColour = "BLUE";
//sb.sendColour(0,0,1000); // blue 2
case 51:
CurrentColour = "CYAN";
//sb.sendColour(0,1000,700); // cyan 3
case 52:
CurrentColour = "WHITE";
//sb.sendColour(900,900,900); // white 4
case 53:
CurrentColour = "INDIGO";
//sb.sendColour(900,600,700); // warmwhite 5
case 54:
CurrentColour = "PURPLE";
//sb.sendColour(300,200,1000); // purple 6
case 55:
CurrentColour = "MAGENTA";
//sb.sendColour(700,0,1000); // magenta 7
case 56:
CurrentColour = "YELLOW";
//sb.sendColour(900,1000,0); // yellow 8
case 57:
CurrentColour = "ORANGE";
//sb.sendColour(1000,500,0); // orange 9
/* Sets the color of the LED to any RGB Value
led - (int array of three values defining the LEDs pins (led[0] = redPin, led[1] = greenPin, led[2] = bluePin))
color - (byte array of three values defing an RGB color to display (color[0] = new Red value, color[1] = new Green value, color[2] = new Red value*/
void setColor(int* led, byte* color){
//iterate through each of the three pins (red green blue)
analogWrite(led[i], 255 - color[i]);
//set the analog output value of each pin to the input value (ie led[0] (red pin) to 255- color[0] (red input color)
//we use 255 - the value because our RGB LED is common anode, this means a color is full on when we output analogWrite(pin, 0)
//and off when we output analogWrite(pin, 255).
/* A version of setColor that takes a predefined color
(neccesary to allow const int pre-defined colors */
void setColor(int* led, const byte* color){
byte tempByte[] = {color[0], color[1], color[2]};
setColor(led, tempByte);
/* Fades the LED from a start color to an end color at fadeSpeed
startColor - (byte array of three values defing the start RGB color (startColor[0] = start Red value, startColor[1] = start Green value, startColor[2] = start Red value
endColor - (byte array of three values defing the finished RGB color (endColor[0] = end Red value, endColor[1] = end Green value, endColor[2] = end Red value
fadeSpeed - this is the delay in milliseconds between steps, defines the speed of the fade*/
void fadeToColor(int* led, byte* startColor, byte* endColor, int fadeSpeed){
int changeRed = endColor[0] - startColor[0];
//the difference in the two colors for the red channel
int changeGreen = endColor[1] - startColor[1];
//the difference in the two colors for the green channel
int changeBlue = endColor[2] - startColor[2];
//the difference in the two colors for the blue channel
int steps = max(abs(changeRed),max(abs(changeGreen), abs(changeBlue)));
//make the number of change steps the maximum channel change
for(int i = 0 ; i < steps; i++){
//iterate for the channel with the maximum change
byte newRed = startColor[0] + (i * changeRed / steps);
//the newRed intensity dependant on the start intensity and the change determined above
byte newGreen = startColor[1] + (i * changeGreen / steps);
//the newGreen intensity
byte newBlue = startColor[2] + (i * changeBlue / steps);
//the newBlue intensity
byte newColor[] = {newRed, newGreen, newBlue};
//Define an RGB color array for the new color
setColor(led, newColor);
//Set the LED to the calculated value
delay(fadeSpeed);
//Delay fadeSpeed milliseconds before going on to the next color
setColor(led, endColor);
//The LED should be at the endColor but set to endColor to avoid rounding errors
/* A version of fadeToColor that takes predefined colors (necessary to allow const int pre-defined colors */
void fadeToColor(int* led, const byte* startColor, const byte* endColor, int fadeSpeed){
byte tempByte1[] = {startColor[0], startColor[1], startColor[2]};
byte tempByte2[] = {endColor[0], endColor[1], endColor[2]};
fadeToColor(led, tempByte1, tempByte2, fadeSpeed);
