First of all this is my first post and I really doesnt know much about hardware, software,electronic,mechanical,etc so please allow me to be silly most of the time. i decided to put my post here because i felt that in the hardware forum is too advance for me lol. Please give me some advices how normal or tell me if u see anything
Objective of my project : control three or more SMA(shape memory alloy) wires and have feedback control using their resistance reading.
Workflow concept 1:
[input a desire length into the computer]
[ch8595]
[the length is converted into a resistance value and
output to digital potentiometer]
[ch8595]
[feed 5v to both SMA and Digital potentiometer alternatively]
[ch8595]
[compare the voltage of the pull-up resistance(not sure if i get the term correctly please refer to the photo)
print the reading into the computer for data logging]
[ch8595]
[if the voltages are different, control the time of the different time of the power supply to the sma. eg feed the current long enough to make it contract or have the resting time long enough to just to keep it at constant length]
Workflow concept 2:
[ch8595]
[feed 5v to both SMA]
[ch8595]
[read the voltage and the current across the SMA and print the value into the computer]
[ch8595]
[control the PWM while using the reading as feedback control]
Actually what I dont understand and really in trouble now is
- the SMA wire's resistance is so low, it change from around 0.6ohm-1.0ohm, how should i choose my other resistors in the circuit?
- should I use the arduino output port as power supply ? or just use it to control the transistor(switch on/off)
- i read about "processing" software to log data from arduino from Getting start with Arduino book but dont really understand it. Can anyone please explain how it should work to me :-/ in the mean time i will just check processing.com
Thank for reading until the end. sorry for having too many unknowns and questions
Great day to everyone and enjoy your spring.
