Desmond's code for Room Automation Control
#include <Keypad.h>
#include <OneWire.h>
#include <Wire.h>
#include <dht11.h>
#include <math.h>
dht11 DHT11;
#define DHT11PIN 12
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 15000;
long unsigned int pause2 = 10000;
boolean lockLow = true;
boolean takeLowTime;
OneWire  ds(13);  //on pin 48
int mSensor = 2;
float Thermvalue,fahrenheits,Total,Average,lightVal = 0.00,lighty;
float negFahren = 0.00, posFahren = 0.00;
float total,value;
char* ourCode = "#3";
int currentPosition = 0;
int nightLight = A2;
const byte rows = 4;
const byte cols = 4;
char keys[rows][cols] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[rows] = {11,10,9,8};
byte colPins[cols] = {7,6,5,4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
int light = 3,lightSensor=A1;
int k =1,Y=1,T=1,passWord=1,J=0,x =1;
int h = A0;
int Music = A3;
LiquidCrystal_I2C lcd(0x27,20,4);
lcd.init();
lcd.backlight();
  pinMode(light,OUTPUT);
  pinMode(h,OUTPUT);
  pinMode(nightLight,OUTPUT);
  pinMode(Music,OUTPUT);
  pinMode(mSensor,INPUT);
  digitalWrite(h,HIGH);
  digitalWrite(Music,HIGH);
  digitalWrite(light,LOW);
  digitalWrite(nightLight,LOW);
  digitalWrite(mSensor,LOW);
void loop(){
  char key = keypad.getKey();
  if (passWord==1){
    digitalWrite(nightLight,LOW);}
if (key == 'B' && Y == 1 && passWord == 1){
  digitalWrite(Music,LOW);
--Y;}
else if (key=='B' && Y ==0 && passWord==1){
  ++Y;}
 else if (key == 'A' && k== 1 && passWord ==1){
digitalWrite(light,HIGH);
--k;}
else if (key=='A' && k ==0  && passWord ==1){
  ++k;}
else if (key == 'C' && T==1  && passWord ==1){
  lcd.noBacklight();
  --T;}
 else if (key== 'C' && T==0 && passWord ==1){
   lcd.backlight();
   ++T;}
   else if ( key == '1' && passWord == 1){
   if(digitalRead(light)==HIGH){
     ++k;}
   if (digitalRead(Music)==LOW){
   ++Y;}
   if (T==1){
    lcd.noBacklight();
  --T;}}
  else if ( key == '2' && passWord == 1){
   if(digitalRead(light)==LOW){
     --k;}
   if (digitalRead(Music)==HIGH){
   --Y;}
   if (T==0){
    lcd.backlight();
  ++T;}}
 else if (key =='*' && passWord==1){
--passWord;
   getOut();
   delay(30000);
   if (T==1){
    lcd.noBacklight();
  --T;}
   clearScreen();
   if (digitalRead(light)==HIGH){
 ++k;}
 ++Y;}
   for(int i = 0; i < 15; i++){
   getLight();
  getFahren();
  delay(10);
Part 2
while (passWord==0){
 MotionLocked();
  getLight();
  getFahren2();
  int l;
  char keY = keypad.getKey();
  if (int(keY) !=0) {
    lcd.setCursor(14,3);
    lcd.print("    ");
    for (l=0; l<=currentPosition; ++l)
      lcd.backlight();
      lcd.print("*");
    if (keY == ourCode[currentPosition])
        ++currentPosition;
        if (currentPosition == 2)
          ++passWord;
          clearScreen();
          delay(150);
          --Y;
          --k;
          ++T;
        invalidCode();
        getPAss();
void getFahren() {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheits;
  if ( !ds.search(addr)) {
    ds.reset_search();
    return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44,1);         // start conversion, with parasite power on at the end
     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
  unsigned int raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // count remain gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
    byte cfg = (data[4] & 0x60);
    if (cfg == 0x00) raw = raw << 3;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
    // default is 12 bit resolution, 750 ms conversion time
  celsius = (float)raw / 16.0;
 fahrenheits = celsius * 1.8 + 32.0;
  lcd.setCursor(6,1);
    if (fahrenheits < 95.00 && fahrenheits > 55.00  ){
       if(fahrenheits < posFahren && fahrenheits > negFahren or negFahren == 0.00 && posFahren ==0.00){
   lcd.print(fahrenheits);
if (fahrenheits > 75.99 && fahrenheits < 90.00 && lighty < 7.00){
  if (digitalRead(h)==HIGH){
    digitalWrite(h,LOW);}}}
else if (fahrenheits <69.99 && fahrenheits >55.00 && lighty < 7.00){
  if (digitalRead(h)==LOW){
    digitalWrite(h,HIGH);}}}
else if(lighty > 7.00 && fahrenheits < 68.00 && fahrenheits > 58.00){
else if (lighty > 7.00 && fahrenheits > 72.99 && fahrenheits < 90.00){
  Serial.print("Temperature = ");
 Serial.println(fahrenheits);
   lcd.setCursor(0,1);
   lcd.print("Temp: ");
 int chk = DHT11.read(DHT11PIN);
   lcd.setCursor(11,1);
   lcd.print('F');
    lcd.setCursor(0,0);
    lcd.print("Light: ");
    lcd.print(lighty);
   lcd.setCursor(0,2);
   lcd.print("RH: ");
   lcd.setCursor(6,2);
   if((float)DHT11.humidity < 100.00){
   lcd.print((float)DHT11.humidity);}
   lcd.print("%");
   negFahren = fahrenheits - 1.50;
   posFahren = fahrenheits + 1.50;}
Was there, perhaps, a question?
BTW, have
you noticed how hard it is to read stuff when it wanders all over the page?
part 3
void clearScreen()
  lcd.setCursor(0,0);
  lcd.print("                    ");
  lcd.setCursor(0,1);
  lcd.print("                    ");
  lcd.setCursor(0,2);
  lcd.print("                    ");
  lcd.setCursor(0,3);
  lcd.print("                    ");
void getLight(){
   lightVal= analogRead(lightSensor);
    lighty = lightVal/100;
 Serial.print("Light val = ");
 Serial.println(lightVal/100);
 void getOut()
  clearScreen();
  lcd.setCursor(0,0);
  lcd.print("********************");
  lcd.setCursor(0,1);
  lcd.print("** ACCESS GRANTED **");
  lcd.setCursor(0,2);
   int time = 30 - millis()/1000;
  lcd.print(time);
  lcd.setCursor(0,3);
  lcd.print("********************");}
  void invalidCode()
  clearScreen();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("** ACCESS DENIED! **");
  lcd.setCursor(0,2);
  lcd.print("**  INVALID CODE  **");
  lcd.setCursor(0,3);
  delay(3000);
  lcd.noBacklight();
  clearScreen();
void getPAss()
      int l;
  if (int(keY) != 0) {
    lcd.print("    ");
      lcd.backlight();
      lcd.print("*");
        ++currentPosition;
         ++passWord;
          clearScreen();
        invalidCode();
        getPAss();
void getFahren2() {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
    ds.reset_search();
    return;
  ds.reset();
  ds.select(addr);
  ds.select(addr);
  if (type_s) {
  void MotionLocked(){
    if(digitalRead(mSensor) == HIGH){
         //the led visualizes the sensors output pin state
       if(lockLow){
         //makes sure we wait for a transition to LOW before any further output is made:
         lockLow = false;
         delay(600);
         digitalWrite(nightLight,HIGH);
         takeLowTime = true;
         if(digitalRead(mSensor) == LOW){
       if(takeLowTime){
        lowIn = millis();          //save the time of the transition from high to LOW
        takeLowTime = false;       //make sure this is only done at the start of a LOW phase
       //if the sensor is low for more than the given pause,
       //we assume that no more motion is going to happen
       if(!lockLow && millis() - lowIn > pause){
           //makes sure this block of code is only executed again after
           //a new motion sequence has been detected
           lockLow = true;
  void MotionUnlocked(){
       if(lockLow){
         lockLow = false;
         takeLowTime = true;
       if(takeLowTime){
       if(!lockLow && millis() - lowIn > pause2){
           lockLow = true;
          --passWord;
The suspense is killing me.
They all get killed off in the season finale
Spoilsport
