Despairing of a pointer-holding array
Hey guys,
since I spent the whole evening to fiddle about the basics of pointers (and learning quite a lot) I’m now at a point I just don’t get why my ESP32 crashes. It’s only one line of code I really do not understand - I hope someone could bring some light into the darkness…? The line between the hashtags is the problematic one.
And: Why is the address of array1[0] = 0x3ffc00bc within getPointer() and within setup() it is 0 (just before the hashtags)? As far as I understand array is a global variable?
int *arr[3];
int value = 5;
int val2 = 3;
int *array1[3] = {0,0,0};
int *(*getPointer())[3] {
  extern int * array1[3];
  int *pValue= &value;
  array1[0] = &value;
  array1[1] = &val2;
  printf("Address of array1 within getPointer(): %p\n", (void *)&array1);
  printf("Address of value within getPointer(): %p\n", (void *)&value);
  printf("Address of val2 within getPointer(): %p\n", (void *)&val2);
  printf("Content of array1 within getPointer(): %p\n", (void *)*array1); // Address of value
  printf("Address of array1[0] within getPointer(): %p\n", (void *)array1[0]); // Address of value
  printf("Address of array1[1] within getPointer(): %p\n", (void *)array1[1]); // Address of val2
  printf("Address of array1[2] within getPointer(): %p\n", (void *)array1[2]); // Address of array1[2] -> 0x0
  printf("Content of array1[0] within getPointer(): %i\n", *array1[0]);
  printf("Content of array1[1] within getPointer(): %i\n", *array1[1]);
  //printf("Content of array1[2] within getPointer(): %i\n", *array1[2]); // ESP stürzt ab --> vermutl. weil array1[2] leer ist
  return &array1;
arr[0] = &value;
  delay(3000);
  Serial.println("Ready");
  Serial.print("value: ");
  Serial.println(value);
  printf("Address of arr is %p\n", (void *)arr);
  Serial.print("Content of arr[0] is ");
  Serial.println(*arr[0]);
  printf("Address of arr[0] is %p\n", (void *)&(*arr[0]));
  printf("Address of array1 is %p\n", (void *)array1);
  printf("Address of array1[0] is %p\n", (void *)array1[0]);
  printf("Address of array1[1] is %p\n", (void *)array1[1]);
  printf("Address of array1[2] is %p\n", (void *)array1[2]);
  printf("Content of array1[0] : %i\n", *array1[0]); // Das crasht den ESP -> Reboot
  Serial.print("Content of array1[0] is ");
  Serial.println(*array1[0]); // reboots ESP
  Serial.print("array1[0]: ");
  printf("Address of content of array1[0] is %p\n", (void *)*array1[0]);  // reboots ESP
  printf("Address of value is %p\n", (void *)&value);
  printf("Address of getPointer() is %p\n", (void *)getPointer());  // = array1
  printf("Address of getPointer()[0] is %p\n", (void *)*getPointer()[0]); // = value
  printf("Address of getPointer()[1] is %p\n", (void *)*getPointer()[1]); // = val2
  Serial.print("rValue: ");
  Serial.println(rValue);
Many, many thanks in advance and best regards!
Does it still crash at the same point if you replace this:
with this:
int *array1[3] = {&value,0,0};
No, that works properly... and the address of array1[0] is then 0x3ffbebf8, not 0 anymore.
This construct:
Initialises the array to null pointers. It does not create 3 integers somewhere and fill the array with pointers to them, as you might have thought.
Attempts to dereference a null pointer may well cause a crash.
The function getPointer(), which you have not called at this stage, would have initialised array1[0] to &value.
6v6gt:
That's the point. This is so simple, I'm so annoyed of myself right now. Thanks for this quick help!
what is the purpose of the following (never seen such a thing in my entire career)
i specified a non-zero value for array1[0] and that avoided a crash. (i assume an attempt to access address zero is an exception; It generated a segmentation fault on my laptop probably because it is outside the memory space for the task)
   array1 [0] = &value;
with that change, i get the following
Ready
value: 5
Address of arr is 0x3ffc00c8
Content of arr[0] is 5
Address of arr[0] is 0x3ffbebec
Address of array1 is 0x3ffc00bc
Address of array1[0] is 0x0
Address of array1[1] is 0x0
Address of array1[2] is 0x0
Content of array1[0] : 5
Address of value is 0x3ffbebec
getPointer:
Address of array1 within getPointer(): 0x3ffc00bc
Address of value within getPointer(): 0x3ffbebec
Address of val2 within getPointer(): 0x3ffbebe8
Content of array1 within getPointer(): 0x3ffbebec
Address of array1[0] within getPointer(): 0x3ffbebec
Address of array1[1] within getPointer(): 0x3ffbebe8
Address of array1[2] within getPointer(): 0x0
Content of array1[0] within getPointer(): 5
Content of array1[1] within getPointer(): 3
Address of getPointer() is 0x3ffc00bc
getPointer:
Address of getPointer()[0] is 0x3ffbebec
getPointer:
Address of getPointer()[1] is 0x3ffbebec
your modified code
int *arr[3];
int value = 5;
int val2 = 3;
    printf ("\n%s:\n", __func__);
    array1[0] = &value;
    array1[1] = &val2;
    return &array1;
    arr[0] = &value;
    delay(3000);
#if 1
#endif
gcjr:
It actually returns a pointer to an array (size 3) of pointers to integers. I found this site very useful to understand that expression: Declare a C/C++ function returning pointer to array of integer pointers - GeeksforGeeks
alve89:
wow.
but you statically initialize the function pointer, not to a defined function, but to a body of code. why not just define a function?
gcjr:
wow.
Sorry for being not able to explain more, I'm very new to C++ so I'm just trying different code snippets and put them together to get the expected result.
And, before I got the hint again that I should learn C++ with some good books: I'm already doing, but I also like learning by doing.
gcjr:
And now I can prove my sentence from above - I don't understand what you mean?
alve89:
And, before I got the hint again that I should learn C++ with some good books: I’m already doing, but I also like learning by doing.
while i believe we should all practice OOP, i’m not a fan of c++. I’ve learned a lot from kernighan’s books (programming style, c programming language, unix programming environment chap 8)
alve89:
And now I can prove my sentence from above - I don’t understand what you mean?
the C programming language, chap 5.11 describes the use of function pointers where you don’t want to have to conditionally test whether to use a particular function but simply invoked the function that a function pointer is set to. that book illustrates many programming features with very practical examples.
i use function pointers in table driven state machines where the action routines are specified as function pointers in a table for each state and stimuli. using tables makes the state machine easier to understand especially when large
// example state machine
#include <stdio.h>
#include "stateMach.h"
Status
a (void* a)
    printf ("%s:\n", __func__);
    return OK;
Status
b (void* a)
    return OK;
Status
c (void* a)
    return OK;
Status
__ (void* a)
    return OK;
#define N_STATE     3
#define N_STIM      2
typedef enum { S0, S1, S2 } State_t;
typedef Status(*Action_t)(void*) ;
State_t smTransitionTbl [N_STATE] [N_STIM] = {
    {   S1, S2, },
    {   S0, S2, },
    {   S2, S1, },
Action_t smActionTbl [N_STATE] [N_STIM] = {
     {  a,  b },
     {  c, __ },
     { __,  a },
char *msg1 [] = {
    "State machine has 3 states and 2 stimuli.",
    "It has the following state transistion and action routine tables.",
    "A __() represents do nothing and is easily identified in table.",
    "Each row is indexed by a state and each column a stimulus.",
    "Of course, meaningful action routine names are helpful.",
char *msg2 [] = {
    "Enter valid stimuli [0-1]:"
void
smHelp (void)
    for (int i = 0; i < sizeof(msg1)/sizeof(char*); i++)
        printf ("  %s\n", msg1 [i]);
    for (int state = 0; state < N_STATE; state++)  {
        printf ("%8s", "");
        for (int stim = 0; stim < N_STIM; stim++)
            printf (" %d", smTransitionTbl [state][stim]);
        printf ("%8s", "");
        for (int stim = 0; stim < N_STIM; stim++)  {
            if (a == smActionTbl [state][stim])
                printf ("  a()");
            else if (b == smActionTbl [state][stim])
                printf ("  b()");
            else if (c == smActionTbl [state][stim])
                printf ("  c()");
                printf (" __()");
        printf ("\n");
    for (int i = 0; i < sizeof(msg2)/sizeof(char*); i++)
        printf ("  %s\n", msg2 [i]);
static State_t _smState  = S0;
Status
smEngine (Stim_t stim)
    Action_t   func;
    State_t    last = _smState;
    if (N_STIM <= stim)
        return ERROR;
    func        = smActionTbl [_smState] [stim];
    _smState    = smTransitionTbl [_smState] [stim];
    printf ("    stim %d, transition from state %d to %d, exec ",
        stim, last, _smState);
    return (*func) (NULL);
