Deta Space(Struggling to use)
I am currently endeavoring to access the DetaSpace website. Despite having successfully created an account, I am encountering challenges in utilizing its functionalities. My objective is to transmit data from the Serial Monitor, operating at a baud rate of 115200, to the aforementioned website. I kindly seek any guidance or advice on how to achieve this task. Below is the code I am currently working with:
//Lesson1
const int relay = 5;
int sensor_pin = 4;
int output_value;
int led = 18;
  Serial.println("Reading From the Sensor ...");
  pinMode(led, OUTPUT);
  pinMode(relay, OUTPUT);
  digitalWrite(led, HIGH);
  digitalWrite(relay, LOW);
  digitalWrite(relay, HIGH);
  digitalWrite(led, LOW);
  output_value = analogRead(sensor_pin);
  output_value = map(output_value, 550, 0, 0, 100);
  Serial.print("Moisture : ");
  Serial.print(output_value);
  Serial.println("%");
  delay(50);
  while(output_value <= -100) {
    Serial.println("Current Flowing");
    delay(50);
  Serial.println("Current not Flowing");
Thank you.
have a look at how-to-get-the-best-out-of-this-forum
what microcontroller(s) are you using?
how do intend to communicate with Deta Space? WiFi, Ethernet, ????
