Hi, I’m trying to make a servo move to a specific position and then “detach” it, so it stops buzzing once it’s done moving.
Below is my code. The problem is that the servo won’t move at all with “myservo.detach();” in the code. If I remove “myservo.detach();”, the servo will move, but will still buzz. Any help is much appreciated!!
You are not giving the servo time to move to the commanded angle. As an experiment increase the delay and see what happens.
The servo should not buzz when in a commanded position. It sounds like something attached to the servo is trying to move it and the servo is resisting. If that is the case then when you detach() the servo it will no longer try to hold its position and may move.
